Electrical problem technique?
Old Jan 7, 2009 | 02:04 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
I've had some sort of electrical problem with my car since i got it where my voltage is low, regardless of the alternator/battery combination.
I was wondering, what if i were to start the car, and start pulling fuses from the fuse box, to see if the voltage rises, and then i could pinpoint which accessory is drawing too much voltage.
(these fuses would obviously not be necessary in order for the car to stay running)
what are some fuses i could pull?
the only fuses i would have to leave connected?
is this a bad idea to try in the first place?
Thanks in advance everyone
Old Jan 7, 2009 | 02:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Electrical problem technique?
What makes you say the voltage is low?
Old Jan 7, 2009 | 02:53 PM
bigchief's Avatar
my voltage on my dash reads 11-12 after the car is warm, 13 rarely, and only when the car is dead cold..... i've also checked the voltage at the battery, and its always the same as the dash reading
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
