Brake Lights - Always brighter then taillights with lights on
Old Jan 14, 2009 | 03:41 AM
scruba's Avatar
Hi all. My bird's brake lights are brighter then the taillights when the parkers or headlights are on and no brake pedal applied. The 3rd brake light does not come on until the brake pedal is depressed.
Is this a common fault? What should I look for to rectify this?
Cheers in advance.
Old Jan 14, 2009 | 07:52 AM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
Re: Brake Lights - Always brighter then taillights with lights on
My husband's Cav had this problem...only they wouldn't turn off..ever...even with the car off. His was a switch under the brake pedal. Yours sounds like it might be something similar. Check and make sure they're not staying on all the time!
Old Jan 14, 2009 | 07:56 AM
scruba's Avatar
Definately not on all the time. Could be as simple as the wrong wattage bulbs. Will have to check it when I get home in 3 weeks. If not I'll search out the wiring and switches.
Cheers.
Old Jan 14, 2009 | 05:52 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Depending on the year of your car there may be two brake switches. One is for the brake lights the other is for the cruise control and the third brake light. Sound like the previous is stuck.
1992 Trans Am
May 10, 2023 07:19 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
