Universal Cruise Control
Old Jan 15, 2009 | 01:36 AM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
I've seen these Audiovox CCS-100 Universal Cruise Control kits on Ebay all the time and was wondering if anyone has ever installed one or a similar one?
Was it a royal pain or pretty simple? Did it actually work?
Old Jan 15, 2009 | 03:05 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Universal Cruise Control
I have put in dozens of aftermarket cruise controls. The do work o.k. and are not real difficult to hook-up. You will need to locate the speed sensor wire in your car, (provided you have an electronic spedometer dark) brake wire, ignition, power, and ground. You will also have to hook up a vacuum line, mount a vacuum canister, and the cruise unit under the hood. Hooking up the cruise's throttle cable can be a little tricky but usually goes rather smoothly. The throttle cable MUST be hooked up properly as it could fail and hold throttle open. There is also the control stick that gets mounted to the steering column. For a few bucks more an aftermarket turn signal handle with the cruise controls in it can be purchased.
Old Jan 15, 2009 | 03:12 PM
acole88's Avatar
this is what ill be using on mine...
http://www.dakotadigital.com/index.c...prod/prd46.htm
this one comes with the adapter that gives a cable driven speedo the electric signal you need. also, no vacuum canister and you can get the "stock" switch assembly that replaces your turn signal handle.
Old Jan 15, 2009 | 05:01 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
hmmmm......I never realized they made such a simple system for carb car. I am assuming these are for carbureted vehicles. If it is so, can they fit on any brand of carb?
Old Jan 15, 2009 | 10:46 PM
Guro 305's Avatar
Axle/Gears: Stock
Cool! Is there any particular one you would recommend?
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
customblackbird
Oct 1, 2015 04:30 PM
scottmoyer
Sep 7, 2015 07:06 PM
