Wiring qtp cutout
Old Jan 21, 2009 | 06:55 PM
Rocksiroc's Avatar
Wiring qtp cutout
im about to install a qtp cutout in my car and needed some advice as to where is the best place to get 12 v switched power from for the switch. Give me ur advice guys.
Old Jan 22, 2009 | 05:32 PM
Rocksiroc's Avatar
Re: Wiring qtp cutout
No one has a idea of the best way to wire this?
Old Jan 28, 2009 | 08:10 PM
Rocksiroc's Avatar
24 views no opinions come on guys
Old Jan 29, 2009 | 10:05 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
from what im understandin is that yur tryin to find a voltage source, well did u not get any instructions, but if there are 3 wires, a hot a neutral and a ground then there are all kinds of hots around the car. Just expierement man i would know more about it if i had one myself.
Old Feb 2, 2009 | 09:25 AM
51F1's Avatar
Car: 1991 GTA,1951 ford f1 pickup
Axle/Gears: 3.42 10-bolt
where are you mounting the switch? cigarette lighter has a 12 volt source that most don't use if you mount the switch on the console.
Old Feb 4, 2009 | 10:56 PM
Rocksiroc's Avatar
I was thinking of using the power from the cigarrete lighter, but its constant power not switched power. In the directions it says to use a switched source cause it can run ur battery, which makes no sense to me cause the motor should not draw power till the switch is used. Correct me if im wrong
Old Feb 4, 2009 | 11:04 PM
Rocksiroc's Avatar
Let me rephrase that the directions tell u too use a switched 12v source
and not a constant 12v source cause they say id use a constant 12 v source it can run the battery down. This makes no sense to me, cause how is the cutout motor going to draw power when the switch is not being operated.
Old Feb 5, 2009 | 07:50 AM
51F1's Avatar
there is a switched source on the radio if you don't mind tying into that. I never checked but under my console there was w bunch of wires that were not connected to anything maybe you have them also and perhaps 1 is a switched 12 volt source.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
formula_novice
Sep 5, 2015 03:58 AM
Bryan F
Aug 27, 2015 07:28 AM
