Turn Signals and running lights dont work.......
Old Jan 27, 2009 | 08:22 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Ok i have a 1991 RS. originally a 305 tbi now its a 350 tbi.
Today me and my friend decided to drive up on top of the parking garage and snap some night shots of our cars. However, when taking the pics my friend noticed my running lights were not on, he asked me to put them on and i thought they were on, the **** was pulled out halfway. seems like they are not working. the rear tails work fine and the headlights come on but the running lights do not. When i put the turn signal on the front blinker flashes(both sides respectivly) but the side marker never flashes (again both sides). All during this the headlights and tails work. The only two that dont work are my side markers(never come on) and my front running lights(only come on when turn signal is activated). Awhile ago i pulled my aftermarket alarm system out and it was wired into the headlights. I spliced some wires but it seems like if it was an electrical wiring problem then they would not work at all. I touched the ignition wire, a ground wire, a power supply wire and two wires going towards the headlights. I dont have a wiring diagram so i dont know which wires to check, all my fuses are fine also.
Old Jan 27, 2009 | 08:26 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Turn Signals and running lights dont work.......
might want to check for broken bulbs and flasher first. start there before getting into wires and such.
Old Jan 27, 2009 | 08:38 PM
Saber's Avatar
Forgot to add that the bulbs are fine too, i checked them out. They look brand new and were put in about 6 months ago anyways. Its just puzzling me as to why they work sometimes, but not others.
Old Jan 28, 2009 | 08:45 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Since you say that tail lights work and front bulbs are good, I'd check the voltage on the brown wire on any of the front sockets. If you have no voltage there (with the lights on, of course ), you might have a broken brown wire somewhere.
The brown wire travels from the dash to the bulkhead connector C100 (on the driver side), through the firewall next to the brake booster, along the driver side fender, to the driver lights, then traverses to the passenger lights.
Hope this helps.
Lou
Old Jan 29, 2009 | 02:48 PM
Saber's Avatar
Hope this helps.
Lou
alright, im almost positive i spliced a brown wire removing this alarm thing i had in my car, ill check it out tomorrow.
Does the same brown wire feed to the front turn signals? Or just to the side markers?
Old Jan 29, 2009 | 04:34 PM
BigBadLou's Avatar
Engine: TPI
Front and side markers, both.
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
