HEADLIGHT WONT MOVE
Old Jan 31, 2009 | 02:54 PM
am1wenzel's Avatar
Car: 89 firebird
HEADLIGHT WONT MOVE
I HAVE AN 89 FIREBIRD, I HAVE TO MOVE THE LIGHTS MANUALLY. CHECKED VOLTAGE TO THE MOTORS AND ARE GETTING JUICE. BOTH LIGHTS QUIT WORKING AT THE SAME TIME. IVE READ ALOT ABOUT THE FUSIBLE LINKS BUT CAN NOT FIND THEM. I WOULD ASSUME SINCE THE MOTORS ARE GETTING POWER ALL THE RELAYS WOULD BE GOOD. SO AM I LOOKING AT REPLACING THE MOTORS?
Old Jan 31, 2009 | 03:00 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: HEADLIGHT WONT MOVE
Theirs a simple rebuilt kit for them, http://www.top-downsolutions.com/pro...products_id=87
The bushings turn to dust in them
Old Jan 31, 2009 | 03:07 PM
am1wenzel's Avatar
Car: 89 firebird
I CAN MOVE THE LIGHT MANUALLY SO IT SHOULD BE AN ELECTRICAL PROBLEM RIGHT?
Old Jan 31, 2009 | 03:09 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
I could move mine manually also when my bushings were beat.
ps. turn off the caps please, I feel like I'm getting yelled at.
Old Jan 31, 2009 | 03:10 PM
am1wenzel's Avatar
Car: 89 firebird
my bad, when i looked at the link you sent. it made it sound like a rebuild wasnt what i needed. the motors dont run at all, is this the same problem you had
Old Jan 31, 2009 | 03:28 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Are they plugged in? If not, then if they motors aren't turning, you need new ones.
Old Jan 31, 2009 | 03:32 PM
am1wenzel's Avatar
Car: 89 firebird
thats what i was afraid of, i just thought that it was crazy that both of them quit working at the same time
Old Jan 31, 2009 | 03:38 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Oh, both my motors did run. I though you said they were getting power meaning the ran.
Old Jan 31, 2009 | 05:46 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Check for power at the wires leading to the motors beyond the connector plug. You may have corrosion at the connectors.
Lon
nova983
European Region
Nov 2, 2015 12:15 PM
codeysabatini
Sep 20, 2015 11:36 AM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
