Reverse light.
Old Feb 1, 2009 | 01:01 AM
upincomin's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock?? I'm not sure
Reverse light.
Ok, So I looked around a bit and didn't find much. Seems like everything is more for the t-5. My car's reverse light just cut out. The tail lights seem fine to me. All bulbs work, but neither reverse light works. I tried calling the parts store, but they only seem to have the manual transmission back up light switch too, are these interchangable? Are there any other things I should check first before i try buying the switch from the mainland? I'm out in Hawaii by the way.
92 Camaro, 305tbi 700r4 trans. Hope that helps somewhat.
Old Feb 1, 2009 | 08:53 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: Reverse light.
the lights work from the shifter, try getting a chilton book, and track the wires down on schematic, if you cant find a new one goto half .com
Old Feb 16, 2009 | 03:47 PM
upincomin's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Reverse light.
I think I found the part is it this semi circlular piece?
Old Feb 16, 2009 | 04:42 PM
chads89ta's Avatar
Engine: 305 tpi
Transmission: t-5
Re: Reverse light.
that is it, but i cant remember what wires are for the r- lights
Old Feb 16, 2009 | 04:43 PM
upincomin's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Reverse light.
Do they sell this piece anywhere? Like at checkers? Or special order threw GM? Or another site or something?
Old Feb 16, 2009 | 04:46 PM
upincomin's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Reverse light.
Also, I noticed, the 2 bolts that are supossed to hold that part in, were not there at all. It kind of just sat in there. Is the piece I have in the picture supossed to go under the tabs or over when you bolt it back in?
Old Feb 16, 2009 | 09:03 PM
upincomin's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Reverse light.
Hope this thread helps someone else out sometime. That part in the pics worked. The reverse lights work again, and in addition to that, the car will no longer start up in any gear it wants, has to be in Park, or maybe neutral too.
Thanks man for your help. Now I can switch off from my 92 T-top and my '99 Hardtop Hugger Orange SS . Tryin' to keep the miles low on that one and this will help.
Old Feb 17, 2009 | 10:25 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Reverse light.
Great job, glad you figured it out!
For anybody: AutoZone for exapmle sells a replacement switch for $17. Duralast part # DR414. You just gotta ask an employee who can read, type and think.
Lou
Old Feb 17, 2009 | 06:18 PM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
Re: Reverse light.
I'm having problems with my switch. How did you take yours out? I know I have to unscrew the top and unplug the wires but I can't seem to take it out. The console seems to be in the way. Did you have to take out the console?
Old Mar 23, 2009 | 12:34 PM
Car: 1989 GTA
Engine: 350 tpi
Re: Reverse light.
Did you have to take the console out? I having trouble with my reverse lights. I can unplug the wire connected to the switch but I don't have room to remove it. It seems that I need to remove the whole console. Is this how you did it?
FormulasOnly
Jul 23, 2018 08:47 AM
Veaceonee
Sep 29, 2016 08:15 PM
Grant2k
Apr 4, 2016 08:21 AM
HoosierinWA
Oct 7, 2015 10:15 AM
84redta
Sep 19, 2015 09:58 AM
