Helllpppp!!! how do you tell if you have a bad fuse
Old Feb 10, 2009 | 11:44 AM
Snikker's Avatar
Car: 1998 Pontiac Firebird Trans-Am
Engine: Ls1 Modified intake magnaflow duals
Transmission: 6spd Manual
Axle/Gears: Stock
I suspect my cooling fan fuse may be bad in my 1994 v6, yes it does have an electric fan ( i personally wish it didnt), i found the fuse under the hood in the box, but being the type of fuse it is i have absolutely no idea how to tell if it's still good. http://www.rockauto.com/catalog/rafr...1035863k951010 see the part number Airtex # 1R1057 thats the one (black box 5 pin fuse). if anyone has any suggestions or a way to tell if either the fan motor is bad or if it's the fuse thats bad that would be very helpful.
EDIT::
I plan on doing an oil change this afternoon so ill check to make sure that i don't have a blown head gasket while im under there to make sure thats not why my car is overheating
Old Feb 10, 2009 | 12:31 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Helllpppp!!! how do you tell if you have a bad fuse
That is a relay. Pull it out and take it to autozone or something similar and they will check it for free. If it works, it should make a clicking noise or you should feel it click.
Old Feb 10, 2009 | 12:41 PM
Snikker's Avatar
Axle/Gears: Stock
EDIT:::
Would that cause it to overheat in traffic? I know it's not the air dam because it runs at the correct temp on the highway at around 75 mph so obviously it's getting air then, what temp would the engine have to reach before the fan should come on? im gonna check it all out later today.?..
Old Feb 10, 2009 | 07:38 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
These fans don't come on until the engine gets pretty warm, over 200 degrees. If the fan is not coming on it will sure make the engine run hot in traffic.
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
90formulaVortec
Sep 3, 2015 09:26 AM
