The Most Absurd Problem EVER!
1992 Z28 350 TPI
My Window on the driver side has some sort of short in it that causes the car to stall if you try to roll the window down.
Also, It wont roll back up!!! No fuses are bad no relays I have check just about all of them. Also, the AC stopped working and the electric fans for the radiator and condenser coils.
But the passenger window and the trunk motor window both work. All I can say Wtf......
Any help?
I have never seen this in any car since I have been working on them at the age of 8....
I thought this was a Chevy not a FORD ( Fix or Repair Daily)
Any help?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: The Most Absurd Problem EVER!
Is it possible somebody has installed some sort of kill switch somehow tied to the window switch, or closely related wiring? I used to have a Z28 that somebody rigged so it wouldn't start unless you turned the headlights on.
Does it stall flat out immediately when you press the button? Or does the act of rolling down the window cause the engine to struggle, eventually stalling, as if excess load is being placed upon it?
Car: 88 GTA "Cocaine"
Engine: 350 tpi
chase the wires from the window switch in the center console and the wires from the fuse box
It is like there is excess load causing the engine to struggle. There is no kill switch im the original owner of the car and nothing was installed like that by my father or I.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
See if your left motor is defective or the mechanism is binding.
Disconnect the left motor and see if the window switch still bogs your electrical system.
Your AC will not work properly if the coolant fans are not.
So get the fans working before looking into the AC system itself.
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsHow bout those dorks too scared to drive without headlights in the daytime!
Car: 1987 Pontiac Trans Am
Engine: 355
Axle/Gears: 10 bolt gm
haha had a problem like this too turned out my switch was stuck in the down position. couldn't get it up and it drained all the power
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
1992 Z28 350 TPI
Any help?
Any help?
