87 firebird with unusal turning signal problem
Old Feb 19, 2009 | 01:52 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
everytime i turn my lights on my dash my right turning signal light comes on with it. and but when i turn the turning signal to go right the light wont come on outside of the caR.
how do i fix this
Old Feb 19, 2009 | 02:08 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 87 firebird with unusal turning signal problem
Have you checked to see if maybe you have a bulb burned out?
Old Feb 19, 2009 | 02:22 PM
jaybdaboat's Avatar
would that make the light inside of my car stay on?
Old Feb 21, 2009 | 07:22 AM
redltcamaro's Avatar
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
how do i fix this
not picking on you or anything but i have an 87 camaro with a v6 and my trans is a 200r4 not a 700r4.
as far as the turn signal problem it sounds like there is a short in your harness. maybe someone had done something to it before you got the car. i would check the bulbs first but it sounds like it is more than just a bulb. also maybe the cluster is shorting out just things to check.
Old Mar 2, 2009 | 12:43 PM
slimmeh's Avatar
Car: 1987 Pontiac Trans Am
Engine: 355
Axle/Gears: 10 bolt gm
check your relay aswell
Old Mar 2, 2009 | 01:24 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
when that happened to me, it was that seperate wire on the front turn signal plug. Mine you can pull out and look at it, i forget why, but i just remember that my problem was up there.
Old Mar 2, 2009 | 09:23 PM
jaybdaboat's Avatar
i do have a 700r4 they come stock on this model.
and i figured out the problem it was my car telling me my alt was going out.
cuz eventually it did go out, replaced it and the problems gone
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
