Fixing the locks
Old Jan 10, 2009 | 01:11 PM
Jhook's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0
Fixing the locks
Anyone know how to fix the door locks so their not so slow and you have to press the button a billion times?
Old Jan 11, 2009 | 12:08 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Fixing the locks
Rplace the doore lock switches and the lock motors in the doors. Parts are relativly cheap.
Old Jan 11, 2009 | 12:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Clean with WD-40, then lube with white grease--do the window tracks while you're at it. The following link may suggest some other fixes while you're in the door panel:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Jan 11, 2009 | 12:55 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Are new door lock switches still available through GM?
Old Jan 11, 2009 | 01:01 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
JamesC
He means clean the lock and latch mechanism. If your door key doesn't turn freely then the electric lock mechanism is going to have the same resistance to unlocking the doors. New power locks, in most cases, won't solve the problem-provided, of course, that the current ones are working-at least 'trying' to lock/unlock.
Old Jan 11, 2009 | 01:19 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
JamesC
Yep, WD40 worked great on mine. I wasn't really able to get in there to apply any grease. It was pretty difficult just getting the WD40 straw in there. But, I was able to bend it around to get all the moving parts of the linkage.
Old Mar 3, 2009 | 03:38 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
How would you know wether or not you just need to clean/lube the tracks up or replace the switches and motors? My driver's side doesn't work at all most of the time, but occasionally they will "try" to lock, but won't do anything. The passenger side always "tries" to lock, but doesn't do anything. You can hear it trying to lock, but it fails. So should I just take the door panels off, clean the tracks and lube them up?
Old Mar 3, 2009 | 06:30 AM
naf's Avatar
naf
There are no 'tracks' for the door locks. The actuator is connected to the latch by a rod.
You can try to clean the latch without removing it by spraying with WD40 but I've always had better luck removing the latch and soaking it in a parts cleaner.
Old Mar 3, 2009 | 06:47 AM
JamesC's Avatar
Originally Posted by DyingYoung138
My driver's side doesn't work at all most of the time, but occasionally they will "try" to lock, but won't do anything. The passenger side always "tries" to lock, but doesn't do anything. So should I just take the door panels off, clean the tracks and lube them up?
Yes. Given the symptoms, it sounds like your car is a prime candidate for a thorough cleaning.
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
