fusible link location
Old Feb 24, 2009 | 02:52 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
89 GTA
Both fans quit working at the same time.
Everything checks out ok exc. the orange wire to the relays is "Hot at all times" putting a volt meter across the org and blk/red reads 12.4v and shorting these out should activate the motors, it doesnt. Installing a 12v light between the org and blk/red does not light. So somehow the volt meter is getting fooled. I think its the fusible link in the org wire somewhere between the relays and ?.
Anyone have any idea where this link is on the car itself.
Old Feb 24, 2009 | 04:52 PM
injdinjn's Avatar
Re: fusible link location
Found it, behind battery under alarm siren.
replacing with 20amp fuse.
20amp wasnt enough, the motors draw 35a on startup then run at 8a. Installed a 30 amp, started the motors 3-4 times each then started both at the same time 2-3 times and then let them run for about 5min and the fuse wasnt even warm, so will try that.
gta892000
Aug 11, 2019 11:16 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
tonys91rs
Sep 2, 2015 07:07 PM
