freakin alarm help please
Old Mar 4, 2009 | 01:00 PM
tgk7203's Avatar
I bought on of those alarms off ebay and now am regretting it. I hooked it up and it will not arm it has power and ground plus all other conections what would cuase the alarm not to arm
Old Mar 4, 2009 | 09:29 PM
tgk7203's Avatar
Re: freakin alarm help please
help someone
Old Mar 4, 2009 | 09:37 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Do you have power door locks, windows ect?
Old Mar 4, 2009 | 11:00 PM
tgk7203's Avatar
I am going to install power windows and locks but dont have them yet
Old Mar 5, 2009 | 11:32 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Some units require power locks to arm its self. Which kit did you buy?
Did it come with directions ?
Old Mar 5, 2009 | 11:53 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Alarms are very tricky to install with all the wiring, if you have the basics hooked up (ground and power) it "should" arm
But if the alarm's negative trigger is hooked to a circuit that is showing a constant ground (ie; doors opened, or bad pinswitch)...it most likely won't arm until that circuit is broken.
Alarms will also not arm itself if the constant 12 volts and the ignition switched 12 volts are reversed. The purpose of the ignition switched 12 volts is so the alarm doesn't arm itself with the car running...so it blocks the arming capability when it's on.
I perosnally would unhook all of the sensors and triggers, and leave the bare basics....constant 12 volts, ignition switched, and ground hooked up...along with the siren. Then see what you have.
Old Mar 17, 2009 | 07:51 AM
Car: 1971 Camaro
Well? ......did you get your problem fixed?
1992Z28!
Nov 19, 2015 07:33 AM
Stauf
Aug 24, 2015 08:31 PM
camaro 22
Car Audio
19
Sep 25, 2001 02:53 AM
ADAM NEAL
Car Audio
Sep 19, 2001 11:24 PM
AmorgetRS
Car Audio
Sep 8, 2001 11:12 AM
