Voltage draining
Old Mar 11, 2009 | 12:52 PM
axl4u2000's Avatar
Car: 1985 pontiac trans am
Engine: V8 305
Axle/Gears: see tranny type
Voltage draining
Hello,
I recently replaced the alternator, battery in my car but everytime the cooling fan comes on the voltage drops significally. Also when the lights are on and the cooling fan kicks in the voltage meter drops almost to the last quarter of the gauge. Needless to say when i turn my signal lights while my headlights are turned on, the turn signal blinks really slow. Any suggestions?
Old Mar 12, 2009 | 08:30 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Just because the alt is new doesn’t mean it‘s good.
Bring it to a place that has good test equipment so they can test it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em off slow pokes.
How bout those dorks too scared to drive without headlights or in the daytime!
Old Mar 12, 2009 | 12:52 PM
Shroken's Avatar
Car: '85 Trans Am
Engine: 350 Crate Motor
Axle/Gears: 3.27 posi
Re: Voltage draining
Happy Racing!
maybe......however I have a similar problem with my rear defroster. Since I first bought the car 4 years ago I have replaced the alternator and battery because they were bad. Since then I have also added coolant fans from a later car and I have never had a problem with the voltage even with all the fans and headlights on, but when I turn only the defroster on, my voltage drops to approximately 9 or 10 volts.
Old Mar 12, 2009 | 01:36 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Verify the gauge with a multimeter. Those gauges are not always correct.
Old Mar 12, 2009 | 02:42 PM
Shroken's Avatar
Car: '85 Trans Am
Except that when the headlights dim and the turn signals slow down their cylces, like in both our cases, it means that there is less voltage....right? (due to the device drawing too many amps??? I'd think that would blow a fuse but ???)
Old Mar 12, 2009 | 02:44 PM
Toehead's Avatar
He never said the lights dimmed. It's difficult to quantify dimming.... it is completely subjective.
Slow blinking could be another problem. Check it with a multimeter to be sure.
Old Mar 12, 2009 | 02:47 PM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
have you checked the voltage regulator?
Old Mar 12, 2009 | 02:50 PM
Toehead's Avatar
The regulators are internal on these alternators. The best way to check is to get a voltmeter and watch the voltage output as you load the alternator.
You can also set the voltmeter to AC volts, and read the ripple voltage that leaks past the diodes. If this voltage is too high, it indicates that one of the diodes is defective. This can also cause low output.
The good news is new brushes, bearings, a regulator, and a diode pack are pretty cheap compared to a reman alternator, and you are sure it's put together correctly.
Old Mar 31, 2009 | 10:54 AM
axl4u2000's Avatar
Engine: V8 305
I had the alternator replaced twice already. I don't know if the mechanic is installing the right alternator with the right voltage but the funny thing is that when it first gets replaced ( the alternator ) it won't drain voltage for the first few months or so. Then it starts doing it again. It just drains the voltage when the fan comes on and if I am driving with the lights on then it gets scary because it drops almost to the last quarter on the voltage meter. I know the voltage meter is not accurate as I already tested it but it is off only by 1-2 volts so if it is dropping to the 9 or 10 volts with the lights and fan on then it is not good.
Old Mar 31, 2009 | 01:41 PM
NINÅ's Avatar
Transmission: 765R4
AMPED UP
You might have an intermittent short in you car damaging the alt.
Install a fast-acting fuse in line with the output of the alt.
A 100 ampere fuse should be enuff.
Happy Racing!
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
SRKLEGIN
Oct 29, 2015 06:38 PM
raymondandretti
Sep 27, 2015 06:43 PM
327IROC85
Sep 23, 2015 12:11 AM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
