Hazards but not blinkers
Old Mar 18, 2009 | 08:28 AM
adamlinn13's Avatar
I was on my way home from work, I was taking a left, I had my left turn signal on, all of a sudden the blinker stopped working. I tried the right blinker and nothing. I tried the hazards and all 6 turn signals worked (2 in the front, 2 in the back, and 2 on the front sides). Also, a fuse keeps blowing that has the dome light, fuse area light, trunk release, and radio. Even if the radio isn't on the fuse blows.
Please help!!!
Old Mar 18, 2009 | 08:54 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Hazards but not blinkers
Not sure if it's the same circuit, but some thugs to try is switching the flashed unit for the hazards to the blinkers one. The two flashed units are located in the "convenience center" under neath your dash above the ALDL plug. Drop that down and you will see the two flashers, try switching them. I don't think that you have a short withthe bulbs because then your flashers shouldn't work.
As far as the fuse blowing, check and make sure that nothing accidentally got dropped in your cigarette lghter hole. Common proble with our cars. Otherwise you will have to trace all wire to try and find the short. Otherwise there is alway the paper clip trick. Replace the fuse with a paperclip and look for smoke, LOL. Last thing I would recomend, by it's been done for years. Obviously f you do try that, protect yourself withgloves a be do not hold the paper clip there for long. I'd also recomend unplugging your radio to protect that.
Old Mar 18, 2009 | 08:56 AM
84redta's Avatar
Double post
Old Mar 18, 2009 | 08:57 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Did you check the TURN B/U fuse? It powers the turn signals and back-up lights (do those work?). It's separate from hazards.
If it's not the fuse, it could be the flasher which is attached by a clip to the side of the fuse block under the dash. You can swap it with the hazard flasher (in the convenience center, next to the door chime module) and see if that does anything.
Hope this helps.
Lou
P.S.: 84redta was a few seconds faster.
Old Mar 18, 2009 | 11:11 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
turn signal relay
Hazards will still work if the relay goes bad but the turn signals will not blink at all either off or staying solid.
Old Mar 18, 2009 | 02:29 PM
adamlinn13's Avatar
Hope this helps.
Lou
The only present fuse that is blown is the radio/light/trunk fuse...unless it's one of the bigger silver things in the same area as the standard fuses.
for all the help
Old Mar 18, 2009 | 02:34 PM
adamlinn13's Avatar
I believe the cigarette lighter thing doesn't work, so it might be that. I'll try to unplug all the lights, trunk release switch, disconnect the radio, and try to see what makes the fuse blow.
Thanks for all the help so far
Old Mar 18, 2009 | 03:16 PM
adamlinn13's Avatar
Update
I got the wiring diagram from Autozone.com for my 1984 Camaro V8 5.0L automatic, and it looks like the lighter and dome/courtesy lights are on the same fuse, and it's listed as a 20A fuse, but what's in there is a 15A fuse. Dare I try to replace the 15A with the 20A it says to have there?
Old Mar 18, 2009 | 04:49 PM
hafton's Avatar
Re: Update
i have the same problem but it is only the right that does not work and when the turn signal is in the neutral position the right arrow is always on and the left works as do my hazards
Old Mar 19, 2009 | 09:13 PM
adamlinn13's Avatar
Update
I switched the turn signal flasher with the hazard flasher and it worked. So, I need a new turn signal flasher. I also disconnected the cigarette lighter and put in a new fuse, so far it hasn't blown. I need to let it sit in there for a bit longer until I can be sure. I also took out the headliner so I could replace it since it's like a old lady...droopy and crusty...ewww
Twin_Turbo
Mar 14, 2016 10:10 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Jimmy91RS
Sep 28, 2000 02:16 PM
