145 mph speedometer?
Old Mar 21, 2009 | 05:36 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
I have a Standard 88 Camaro with the 115 mph speedometer. Would a 145 mph from a z-28 work in my car? Would i be better off just getting aftermarket guages?
Old Mar 21, 2009 | 05:39 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Re: 145 mph speedometer?
it's a direct bolt in.
Old Mar 21, 2009 | 05:43 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
I replaced the 85 mph speedo in my '85 with a 145 unit with no problems . I got really tired of pegging the needle against the reset button. There are usually a few 145's on E-bay at any time. you can get the whole cluster or just the speedo. Good luck.
Old Mar 21, 2009 | 05:44 PM
HankL69's Avatar
Engine: 5.0 / 350
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
To avoid any electric problems with the cluster, I'd suggest swapping in the speedo head only.
JamesC
Old Mar 21, 2009 | 05:45 PM
HankL69's Avatar
Engine: 5.0 / 350
Old Mar 21, 2009 | 05:47 PM
JamesC's Avatar
Hey, Hank,
Maybe hit that button an extra time or two (I hate when that happens) .
JamesC
Old Mar 21, 2009 | 05:52 PM
HankL69's Avatar
Engine: 5.0 / 350
Originally Posted by JamesC
Hey, Hank,
JamesC
I'm trying to figure out how to un-do it right now. Lesson learned!
Old Mar 21, 2009 | 05:56 PM
chevman24's Avatar
I bid on one on ebay. Did you change the whole cluster or speedo?
Old Mar 21, 2009 | 06:02 PM
HankL69's Avatar
Engine: 5.0 / 350
I changed just the speedo. the complete clusters tend to sell for more $$$.
Old Mar 21, 2009 | 06:06 PM
chevman24's Avatar
How much was the speedo? Since im in the same area i figure it should cost the same
Old Mar 21, 2009 | 06:20 PM
HankL69's Avatar
Engine: 5.0 / 350
I swapped mine a couple of years ago and can't find the details. I reaslly don't remember what I paid. I only remember that it was worth it.
Old Mar 21, 2009 | 06:26 PM
chevman24's Avatar
Did you need to change the speedometer gear drive in the transmission? Found one on ebay for 95.00 does that sound familiar? Its brand new though
Old Mar 21, 2009 | 06:39 PM
HankL69's Avatar
Engine: 5.0 / 350
I swapped mine a couple of years ago and can't find the details. I reaslly don't remember what I paid. I know that I bid on a couple before I was able to get one for what I was willing to pay. I only remember that it was worth it.
Old Mar 21, 2009 | 07:02 PM
HankL69's Avatar
Engine: 5.0 / 350
Old Mar 21, 2009 | 07:06 PM
HankL69's Avatar
Engine: 5.0 / 350
I did not have to change the trans gear. That would only have to be done if you were changing the rear gear. (once again I was too quick on the send button, My bad)
Old Mar 21, 2009 | 07:21 PM
chevman24's Avatar
Do you know what color speedometer gear i would have to use if i changed gears? It has 2.73s in it now and im planning 3.73s. Thanks
Old Mar 21, 2009 | 08:11 PM
HankL69's Avatar
Engine: 5.0 / 350
that's quite a jump from 2.73 to 3.73. Sorry, but I'm not familiar with auto trans driven gear colors or teeth numbers.
Old Mar 21, 2009 | 08:27 PM
chevman24's Avatar
Thanks for the info. The car is a real dog until it hits 3000 rpms but then it only has 1500 more before it has no power.
Old Mar 21, 2009 | 10:09 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Be aware that 87 and later cable driven speedos have a speed sensor that the earlier ones do not. Also the odometer reset buttons are in a different place.
Old Mar 22, 2009 | 08:02 AM
chevman24's Avatar
I converted the car to a Carb setup and took out the computer. So the speed sensor shouldnt be needed. Thanks for the info.
Old Mar 22, 2009 | 08:13 AM
JamesC's Avatar
I'm unsure what speed sensor you're referring to. As far as I know all Camaro VSS's were on the rear of the cluster from 82-89. At least from 85-89 (and perhaps earlier), the reset is at the bottom on all speedo heads.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
