new engine need help wiring up
Old Mar 22, 2009 | 09:43 AM
zombiereaper205's Avatar
ok well i replaced my old 305 with a new 350 i really need to know what these two wires do, cause im super lost i was told one goes to the knock sensor and the other iono but i also need help finding the temp sensor wire .
Old Mar 22, 2009 | 11:31 AM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Re: new engine need help wiring up
The frst one looks like it goes to the brake master cyl or proportioning valve. The second if it is on the drivers side could be the temp sender for the gauge.
Old Mar 22, 2009 | 11:51 AM
OK i think you are right about the 2nd one because it is on the drivers side but it is chewed to hell so can i replace it or will i have to get a new gauge all together? the first one fits snug on the knock sensor but i still don't know, thank you for the help its greatly appreciated.
Old Mar 22, 2009 | 11:57 AM
groundrat's Avatar
Car: 91Z28
Is the sensor messed up or the connector? You can pur a regular crimp connector and use a nut to hol it on.
Old Mar 22, 2009 | 12:06 PM
Its the connector, the sensor is still brand new i replaced it instead of taking it off the old engine. so you say i can crimp it on ?
Old Mar 22, 2009 | 03:20 PM
groundrat's Avatar
Car: 91Z28
No, use a solderless crimp connector. They sell packs of them almost everywhere. Like these:
Old Mar 22, 2009 | 07:08 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
One is the Knock sensor (blue wire) on the low passenger side of block the other is for the fan temp sensor which is in the water jacket above the knock sensor on the passenger side. (same type of connector) There is also a temp sensor by the thermostat housing and on between #1 and#3 spark plugs. YOur local Napa store will have a new connector you can splice in for the broken one.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
