NEW NOS Tach acts like the 20 yr. old one!
Old Mar 25, 2009 | 04:37 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
I bought a new old stock tach and had it put in today. The mechanic said it reads the same as my old one - way too high (+/- 2500 at idle). The new tach is identical to the original and looks absolutely new. The mechanic seems perplexed. Could it be another issue thats causing the misread or did I just buy a defective one?
This is the tach I bought:
http://cgi.ebay.com/ebaymotors/NOS-8...4506.m20.l1116
Old Mar 25, 2009 | 05:08 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: NEW NOS Tach acts like the 20 yr. old one!
The odds of 2 tachs having the same problem.. well, it's more likely the tach isn't the problem.
Old Mar 25, 2009 | 05:25 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea but our tachs are known for doing exactly that, i have had 2 that did the same thing
IIRC its just a resistor you got to swap out, if thats the case west i can fix it for you, just give me or the b'man the tach and i can soder a new resistor or whatever in it, but we would have to have someone on here tell me what to replace
Old Mar 25, 2009 | 05:35 PM
gatorcola's Avatar
Engine: LB9 5.0 tpi
Thanks for the offer Jason, but what gets me is the tachs have a history of working well for many years before they wack out - my original tach was 12 > 14 yo before it did.
Old Mar 25, 2009 | 05:50 PM
89RS_82Z's Avatar
yea........a resistor can burn out after a few years if thats really what causes it read wrong, ill be watching the fourm, if there is a way to fix one of your 2 more than likely i will be able to do it
Old Mar 25, 2009 | 06:04 PM
Burgundy Bomber's Avatar
Car: 84 Z-28, 01.5 Cummins 3500, 98 Ford
Engine: mild 355, built Turbo Diesel
Transmission: th-350
Axle/Gears: soon to be broken, 3.55's in diesel
Mine did the same thing... but after an engine swap.
my Aftermarket one is Zip Tied to the stearing wheel and is working like a champ.
lemmen know if you figure it out, I have a spare 84 that may become a road racer.
Old Mar 26, 2009 | 04:41 PM
gatorcola's Avatar
Engine: LB9 5.0 tpi
The mechanic thinks the tack is ok. He feels that there may be a wire insulation problem that allows static electricity to increase the RPM read. At idle the tach reads 2500 (250% above normal) but the greater the true engine rpm the more off the tach reads. It sounds plausible to me - your thoughts?
Old Mar 26, 2009 | 05:22 PM
89RS_82Z's Avatar
found out some stuff
make sure your connections are good on the dizzy and where the tach plugs into the cluster
your can be fixed, but it would prob take an afternoon and the car would have to be on hand to "tune" the tach
or http://www.bobsspeedometer.com/ can repair
the best that i gathered is its very common to happen to our tachs and that its the tachs themselfs
Old Mar 26, 2009 | 05:28 PM
RedLava's Avatar
Car: 86 z28
The new tach you have is to a v6 that is why is does not read correctly. You can tell this because the oil pressure gauge is to 80 psi. Also because a 6k red line is to a v6
Old Mar 26, 2009 | 05:30 PM
89RS_82Z's Avatar
https://www.thirdgen.org/forums/elec...ach-fixed.html
BINGO!!!!!!!!!!!!!!!!!!!!
bring me your tach and i will fix it
you could also give it to the b'man and have him give it to me......looks like i may be fixin his now, his is starting to go funky to
Old Mar 26, 2009 | 06:34 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Ya, I'm betting that it's the printed circuit board and not the tach itself. It's a quick fix, I had another member fix mine for me, because I am uncomfortable working on printed circuit boards. But my tach is dead on now.
Old Mar 26, 2009 | 08:21 PM
gatorcola's Avatar
Engine: LB9 5.0 tpi
HOLY CRAP - It even says so on the ebay link I posted. Wish I has the sense to read the damn stuff before I bought it. The link says it can be changed to an 8 cyl at a clock, speedo or tach shop. What the hell would they do to it?
I'm an effin idiot.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Luigytico09
Oct 1, 2015 08:46 AM
Eric-86sc
Sep 28, 2015 11:37 AM
ironbmt
Sep 27, 2015 06:00 AM
