Power Windows
Old Mar 26, 2009 | 02:56 PM
HBZ28's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626 LX
Engine: 305 TBI, 2.0 DOHC
Transmission: 700R4, A4
Axle/Gears: 2.73, N/A
Power Windows
Okay, my passenger side window is goofed up. You have to slam on the interior panel in order to "wake it up" and the window to slide back up... what could be the cause of this? I'm glad they still work, I know that's a pretty common little gremlin in our ThirdGens.
Old Mar 26, 2009 | 03:23 PM
1Aauto's Avatar
Former Sponsor
Re: Power Windows
There could be a broken or frayed wire in the wire harness.Sometimes from years of opening and shutting the doors a wire will break.
Old Mar 26, 2009 | 04:02 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Power Windows
Remove the shifter plate and reach in there under the switches. The connectors tend to loosen themselves. The "slam" on your center console merely pushes down on the wires and makes a temporary contact until the car is driven over a bump and the contact is broken again.
Hope this helps.
Lou
Old Mar 26, 2009 | 04:05 PM
HBZ28's Avatar
Re: Power Windows
Thanks... just checked out your site... you will be getting orders from me very soon... the dash pad price is to good to be true!!!
Old Mar 27, 2009 | 09:14 AM
1Aauto's Avatar
Former Sponsor
Re: Power Windows
Not a problem,glad I could help.
Old Mar 27, 2009 | 09:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Power Windows
Could be the sign of a dying motor.
JamesC
Old Mar 27, 2009 | 10:19 AM
BigBadLou's Avatar
Engine: TPI
Re: Power Windows
HBZ28,
by "interior panel", did you mean the door panel?
That would probably point to wires or connectors on the door locks themselves.
Sorry, I originally thought you meant the interior console panel.
Lou
Lou
Old Apr 1, 2009 | 06:03 PM
aldaran's Avatar
Re: Power Windows
I'm having a problem with my passenger window. I lowered it about a third of the way for the day. When I was ready to raise it, it wouldn't and it won't go down any further. The driver side works fine. Is it time for a new motor?
Old Apr 1, 2009 | 07:01 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: Power Windows
More than likely yes. Check your connection, if all is connected to the motor and the window switch check the voltage at the connector. If that is good....new motor.
Old Apr 1, 2009 | 07:02 PM
Car: 1991 Firebird
Engine: 3.1L V6
Re: Power Windows
Originally Posted by BigBabyLou
HBZ28,
Lou
Lou
Have a lot of things on your mind LOU? You went from window connectors to door locks on a thread about power windows.
Old Apr 1, 2009 | 11:49 PM
BigBadLou's Avatar
Engine: TPI
Re: Power Windows
Tell me about it! :-D
As long as we understand each other, it's good.
Lou
Old Apr 12, 2009 | 10:44 PM
aldaran's Avatar
Re: Power Windows
Thanks for the info. I decided to check the switch first and sure enough it was loose. Snapped it in and the window started to work again. I was a little scared to tackle the window motor alone. Thanks again!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
