Can a code 22 be a sign of a bad fuel pump?
Old Mar 27, 2009 | 08:39 PM
Justin1989's Avatar
Car: 1989 GTA
Engine: 5.7L TPI 350
Transmission: Automatic
22. Low voltage at throttle positon sensor OR
Fuel cutoff relay circuit open or shorted to ground
Soo.. I got this code, and my car was acting funny, died alot, then it would run and this would flash on and off.
Could code 22 be a sign of a short in the fuel pump wire or something?
Old Mar 27, 2009 | 09:07 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Can a code 22 be a sign of a bad fuel pump?
I dont think that it would be a sign of a bad fuel pump. I would be most likely a bad or misadjusted sensor or wiring problem. Worst case would be a bad ecm. Here is a chart to help you diagnose the problem.
Attached Thumbnails Can a code 22 be a sign of a bad fuel pump?-code-22-2.jpg
Old Mar 28, 2009 | 02:32 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
is it for the TPS?
i got that code but i forget what it said it was for on all data. ether oxygen sensor, egr or something else.
Old Mar 30, 2009 | 09:48 PM
Justin1989's Avatar
Car: 1989 GTA
It's a TPI..
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Newguy91rs
Aug 7, 2015 09:51 PM
