HELP, i need third brake light bulbs
Old Mar 27, 2009 | 10:35 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
i have searched numerous local parts store. i am looking for the third brake light bulbs for the brake light in the spoiler. any help would be appreciated.
Old Mar 27, 2009 | 10:47 PM
toomany's Avatar
Re: HELP, i need third brake light bulbs
Checked a Napa yet? I just bought 4 of them on tuesday for my 88. I don't know why any other part store wouldn't have them. Are you asking for a buld for the third brake light? Or are you taking one with you? If you're asking...thats most likely your problem. The idiots they get to work at most parts stores can't tell the differance between a headlight and tail light (bulb).
Old Mar 27, 2009 | 10:52 PM
Car: 87 iroc
Engine: 410 sbc
i know what the bulb looks like, i just don't see any on the shelves. maybe i have to ask??? what was the part number, do you remember? i looked in the book and i believe it is 891
Old Mar 27, 2009 | 10:58 PM
Car: 87 iroc
Engine: 410 sbc
http://www.bulbtown.com/891_MINIATUR...BASE_p/891.htm
i do believe this is it....little buggers are expensive!
Old Mar 27, 2009 | 11:00 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
http://www.custom-leds.com/
Way less expensive than even a single bulb for the spoiler.
Old Mar 27, 2009 | 11:11 PM
Car: 87 iroc
Engine: 410 sbc
are those just plug and play? is it the whole assembly with outer lense?? or just replaces bulb assembly??
Old Mar 27, 2009 | 11:15 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
That bulb looks familiar, I think at Autozone we keep that bulb next to the fog lights probably just because the number follows.
Old Mar 27, 2009 | 11:25 PM
Al Hasse's Avatar
If for the LED kit, it's just the LEDs that plug into the same socket as the normal bulbs. Should also have a resistor or current limiting diode to splice into your harness. I bought mine when he still had a deluxe kit and it came with a prewired harness, with the necessary component, which installed between the stock harness and the bulb assy. It comes with the necessary instructions which are easy to follow.
Old Mar 27, 2009 | 11:46 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Do you have a Home Depot close by? Check the outdoor lighting aisle. Look for replacement bulbs for Malibu brand lights. The ones you want are the 10-watt sized bulbs.
Old Mar 28, 2009 | 12:08 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
that is the same bulb that is in the rear interior light. yes they are bright. never took the one in my 90 out of the break light are you sure that is it?
Old Mar 28, 2009 | 12:32 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Radio shack was the only place in town I could find mine other than going online.I like instant gratification if at all possible
Old Mar 28, 2009 | 05:42 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Radio Shack, 20V halogens for $1.99 + tax, or better yet buy the led kit.
Old Mar 28, 2009 | 06:32 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
go to radio shack part # 272-1177 , your wallet will thank you . 2 bux there , 6+ bux at advance . good luck .
Old Mar 28, 2009 | 10:46 AM
Car: 87 iroc
Engine: 410 sbc
thanks, i think i'll head to radio shack.
Old Mar 28, 2009 | 11:33 AM
DJP87Z28's Avatar
A word of advice, DO NOT touch the halogen bulbs with your bare fingers. The oil from your skin will cause hot spots and shorten the bulbs life.
Old Mar 28, 2009 | 07:52 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
quick question, its says standard kit is 2.00 dollars is that for one led bulb?
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
