car wont turn over HELLPPPPPP!!!!!
Old Apr 6, 2009 | 03:14 PM
doop327's Avatar
Car: 86 iroc-z
Engine: 355 vortec heads, 750dp, xe268
Transmission: 700r4 kitted
Axle/Gears: 3.23 posi 10 bolt
i have an 86 z28 with 305 quadrajet and a vacuum advance also a 5 speed. i was at the bank today and i parked on a slight uphill, my e brake doesnt work so i just use first gear. anyway it rolled backwards a few feet i hopped in pressed the clutch i turned the key and NOTHING at all. the terminals are a lil loose but the volt guage reads full until i step on the brake and it reads 8 or the lowest on the guage. im hoping its just the loose terminals . is there anyway to troubleshoot the other obvious causes like the ignition. solenoid, clutch switch, or key?
Old Apr 6, 2009 | 05:50 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Re: car wont turn over HELLPPPPPP!!!!!
What happens when you turn the key? Does anything still function? Radio, door locks? Definitely snug all your connections first and try it again. You may try getting a jump as your battery may have just picked that exact time to give up the ghost on you.
Old Apr 6, 2009 | 06:32 PM
doop327's Avatar
Car: 86 iroc-z
i got it fixed this evening battery decided to take a s*** on me. glad that was all that was wrong.
Old Apr 6, 2009 | 06:38 PM
groundrat's Avatar
Car: 91Z28
Glad you got it all set!
Old Apr 6, 2009 | 07:14 PM
doop327's Avatar
Car: 86 iroc-z
thanks for the input though.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 9, 2015 01:15 PM
