alternator ?
Old Apr 6, 2009 | 09:47 PM
mvd72786's Avatar
Car: 1989 Camaro IROC-Z
Engine: 305ci 5.0L (TBI to carb)
Transmission: manual
alternator ?
I dont know much about alternators other than what i've read today trying to figure this out. I took out a good bit of wiring from the engine bay when i switched from tbi to carb in my 89 iroc 305. I got a little bit trigger happy with the wire cutters, and i accidentally cut the wires on the harness on the regulator. I had a wire running from the alternator battery post to the starter, and that was it, and it was obviously not charging. I ran a second wire from the starter to one of the pins where the harness would connect, and it is now charging fine (13.8V). There are 4 pins in the regulator, 3 small and 1 large. I ran the second wire from the starter to the small pin closest to the large pin.
My question is, will this current set up eventually ruin my alternator and/or regulator? At higher RPMs? (I revved a little bit and did not see a jump in voltage) Or is it ok to leave that second wire on the one pin? Thank you.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
