HID wiring help
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
HID wiring help
I just purchased a HID kit for H4 type bulbs (which I have) on my 82 Z28. When everything is wired up to the factory harness, the lights just pretty much flash on then turn off ? They won't stay on ? If I hook up the power and ground directly to the battery, they stay on just fine ?! Do I need a relay to make this work or is there another way to wire this setup ?
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: HID wiring help
Come on man, you been a member for a while.
Did you even try a search yet??????
I seem to post the same diagram over and over again all the time.
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: HID wiring help
Sorry, been reading your posts in the search section for a while now, haven't found a simplified version yet for a novice electronics individual such as myself ! Still reading, looking , and trying to make sense of it all ! Hell, I just got thru reading how to properly wire a relay , LOL !!
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: HID wiring help
OOO K... this was a very helpful post in my time of need. Is there anyone else that is willing to be a bit more productive here with my problem ?? I appreciate it.
Re: HID wiring help
Look at the top and middle images
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: HID wiring help
You HID kit is an H4 kit right? That's the top diagram.
Your stock headlight is the middle.
See how they are different?
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: HID wiring help
There are only 2 wire leads (red and black ) from the kit, I've connected them every way I can according to the diagram and all I get is a flicker from the lights ?
Re: HID wiring help
Do you realize that your gonna loose the hi beams
Re: HID wiring help
so on the "block" that u plug into the stock harness...u only have 2 wires going to the stock connector that has 3?
Car: 82 Camaro Z28
Axle/Gears: 3:23
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: HID wiring help
Anything ?? C'mon guys, you have already accomplished this task, surely it can't be to difficult to pass on your knowledge of this stuff so that people that are stuck can proceed ?
Re: HID wiring help
but if ur kit only has 2 wires, it sounds like you may have bought an hid kit made to be used only as high beams.
please post pics of ur harness and the details from the order reciept that tells you what you ordered.
maybe the company sent you the wrong kit by accident, maybe you ordered the wrong kit by accident.
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: HID wiring help
umm...we bought h4 hid kits like you are supposed to do. when we installed our kits they had 3 wires from the hid kit plugging into the 3 wires to the stock vehicle harness. we followed the diagram and fixed the wiring mix up.
maybe the company sent you the wrong kit by accident, maybe you ordered the wrong kit by accident. :shrug:
Re: HID wiring help
are u sure u order h4 and not h1
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: HID wiring help
I specifically ordered the H4 HID set up as I was already running 6500k non HID H4 bulbs.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: HID wiring help
interesting info here
Glowsock
Jan 9, 2017 04:06 PM
3rd, beam, conversion, diagram, gen, h4, harness, headlights, hid, issues, kit, lights, sealed, troubleshooting, wiring
