what are these plugs to?
Old Apr 22, 2009 | 12:30 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
here are a couple pics of 2 plugs i cant find what their for the wire colors are on the brown plug tan with 2 white strips and orange the other is black and pink with black stripe
Old Apr 22, 2009 | 11:19 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: what are these plugs to?
well I am guessing that this car has had the fuel injection taken off and converted to carb. the large one is the oil pressure controlled fuel pump switch, (as long as the engine has oil pressure the fuel pump stays on) the other looks like an O2 sensor plug, not sure bad picture. should have a purple wire! and if these are unplugged you must not have injection or it aint runnin right
Old Apr 23, 2009 | 08:38 AM
Car: 87 iroc z
Engine: 358 tpi
no it still has the tpi and runs pretty good i was thinkin the big might be for the power steering because the sensor isnt there or the trans because thats where i found it hanging down there but the other im not shure its not the o2 sensor its hooked up
Old Apr 23, 2009 | 09:05 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Macertheracer is right, the first one is for the oil pressure sender and FPOP (Fuel Pump Oil Pressure) switch. It might be unhooked possibly because the FPOP might be stuck closed, keeping the fuel pump on constantly (common fault).
The second plug looks like it goes to one of the emissions components. Which side of the engine is it on? I looks a lot like the EGR solenoid connector (by the distributor).
Hope this helps.
Lou
Old Apr 23, 2009 | 09:59 AM
Car: 87 iroc z
Engine: 358 tpi
where is that sensor supposed to be.I have a regular oil pressure sending unit that is plugged up and the gage works fine.Also i dont have any problems with my fuel pump(as far as i know) it kicks on when i turn the key on and back off in a few seconds and runs good on the road no trouble codes or anything.The leads on the plug are very long like it would go to the trans or steering.As far as the other plug i unhooked all the smog stuff and removed any thing that went with it.The plug is on the drivers side.
Old Apr 23, 2009 | 11:00 AM
BigBadLou's Avatar
Engine: TPI
The FPOP switch is normally by the oil pressure sender, on top of the block, back by the distributor, driver side. The newer blocks had it down by the oil filter.
If your fuel pump works fine, do not worry about it, it's only a backup system in case the fuel pump relay blows, in which case you don't want to be stranded 100 miles from civilization due to a bad $5 relay.
Lou
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
