is my VATS causing this??
Old Apr 30, 2009 | 10:44 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
I just converted my 89 trans am from tpi to carb, i am almost done with the conversion. I ripped all the wiring out and only used a few wires fromt he bulkhead connector. So far everything works except my car wont crank over. I hooked up the started from the purple wire connection to + and it cranked. so i'm guessing it has something to do with the VATS, i do not have the ECM connected anymore either.
What do you think it could be?
When my car was an automatic i had a viper remote start/alarm system installed,after the t56 i never messed with the remote start again, could that be causing it?
Old Apr 30, 2009 | 10:49 PM
Re: is my VATS causing this??
i do have a push start button just incase i cant figure it out
Old May 1, 2009 | 01:26 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Nice, another jump 100 years back.
If you removed the ECM, your VATS isn't controlling anything anymore.
The Starter Enable Relay is one of the things that has no signal as well.
You need to bypass the relay so that you can use the key to start the engine.
It should be either by the fusebox or behind the driver side kick panel.
Hope this helps.
Lou
Old May 1, 2009 | 10:39 PM
Hope this helps.
Lou
oh ok, so where is the signal comming from for the relay? ecm?
Old May 1, 2009 | 11:36 PM
BigBadLou's Avatar
Engine: TPI
The signal is coming from the VATS box (burried deep in the dash) but if you removed the ECM fuse, the VATS box won't work. If you replace the 10A fuse in the fuse block, the starter might turn, it might be as easy as that.
Let us know how it goes.
Lou
Old May 2, 2009 | 06:34 AM
i never took the fuse out, so i'm guessing my vats is freaking out on me.
Old May 2, 2009 | 07:02 AM
johnhifi's Avatar
Maybe it blew a fuse when you were messing with the wireing. Check that 10 amp fuse like Lou said.
Old May 2, 2009 | 09:36 AM
BigBadLou's Avatar
Engine: TPI
Also, if you removed only ECM wiring, the Starter Enable Relay circuit should be still intact. But if you removed more wiring than that, it's hard to tell.
You can use this troubleshooting article to find the cause of your no-crank condition:
http://www.austinthirdgen.org/index.php?pid=38
Hope this helps.
Lou
Old May 2, 2009 | 06:18 PM
thanks for the help guys ill take a look at it tomorrow if it doesnt rain
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
