Power Mirror Conversion
Old May 19, 2009 | 10:44 AM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
OK so first place I looked to try and find a wiring solution for this was at the wiring diagrams in the Chilton, and guess what, they don't mention anything about power mirrors in any of them.
I've searched all over this site and there were no clear cut answers on how they get wired up into a non-power mirror car.
Has anyone done the conversion from manual to power mirrors and if so where did you guys wire them in??
Old May 19, 2009 | 07:29 PM
Car: 91 Camaro RS
Axle/Gears: 323
Re: Power Mirror Conversion
Bump! Anyone?? I know someones converted from Manual to Power Mirrors!
Old May 21, 2009 | 12:28 AM
jaygod8's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
A couple questions first:
1: Do you have the stock wiring harness or are you just wiring them in?
2: Did your car come with any power options? (locks, windows, trunk pulldown)
If you have the stock harness you just need to run the wires thru the car and hook the power up to C238 (behind the drivers side kick panel). If your car came with any of the other power options it should have the C238 junction block. If not, you probably don't have it and you'll need to splice into an accessory wire. I've been converting my 87 Sport Coupe to ALL power options (Windows, Locks, Mirrors, Seats) and this is the most comprehensive wiring diagram link that I have found:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Hope this helps!
Old May 21, 2009 | 12:47 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i wrote a set of instructions with making a harness and all - let me find the link.
found it
https://www.thirdgen.org/forums/body...r-mirrors.html
Old May 21, 2009 | 09:12 AM
Car: 91 Camaro RS
Axle/Gears: 323
Thanks Guys thats perfect! Almost everything else in my car is power (Windows/Locks/Trunk) only the mirrors aren't. I bought the mirrors off ebay and it was basically everything you need. It came with the harness as well as the switch and everything. I could have probably figured out how to wire this in and rig it up as I'm pretty good with car electronics but I wanted to do it right and have it hooked up as stock as possible.
Thanks Again!
-Chris
Old Feb 24, 2010 | 11:35 PM
cjmelendez's Avatar
Car: 82 trans-am
Engine: 305 4bbl q-jet
I know this is an old post but this is what I'm getting ready to, were you able to do this swap? you said you had the wiring harness with your mirrors, what did you do to make it work?
Thanks for any info.
jaridjohn
Jul 8, 2024 03:49 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 13, 2015 12:59 PM
