engine light on
Old May 20, 2009 | 08:36 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
engine light on
does anyone know how to deal with a engine light that is on. i have an 85 z28 shops say its to old to run machines on it. is there anyway to find out why my engine light is on what is wrong?
Old May 20, 2009 | 09:29 PM
JJx91camaro's Avatar
Car: 1991 chevy camaro rs
Engine: carbed 350 sbc
Transmission: th350
Re: engine light on
u need an OBD-1 code reader
Old May 20, 2009 | 10:03 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
Re: engine light on
all you should need to do is short 2 of the pins on the obd connector and count the flashes on the service engine light. This will give you the codes.The procedure is in my hanes manual with a listing of the codes.
Old May 20, 2009 | 10:09 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: engine light on
You just need a paperclip to read the codes.
This page will tell you how to read the fault codes and what they mean:
http://www.austinthirdgen.org/index.php?pid=27
Hope this helps.
Lou
Old May 21, 2009 | 02:58 PM
n8sz28's Avatar
Car: 85 camaro z28
Re: engine light on
ok thanks for the info i can always count on the members of this website thanks a lot
Old May 28, 2009 | 05:35 PM
n8sz28's Avatar
Car: 85 camaro z28
Re: engine light on
the codes that came up for my car were 24 and 42. i read the meanings of them in the post above but how can i fix them so the light will shut off. i swapped out my automatic tranny to a 6 speed manual and i don't know if maybe this has something to do with one of the codes, since the ECM might think there should be a auto trans and now some wires aren't connected?
Old May 28, 2009 | 10:26 PM
BigBadLou's Avatar
Engine: TPI
Re: engine light on
On TPI engines, code 24 indicates a low TPS reading and code 42 is for the ESC circuit.
You can check the TPS with a voltmeter. The reading with the key on should be as follows:
- throttle closed - 0.5V
- throttle fully open - >4.0V
When opening/closing the throttle, the voltage reading should be smooth, not jumpy.
Lou
Old May 29, 2009 | 10:26 AM
n8sz28's Avatar
Car: 85 camaro z28
Re: engine light on
how do you keep the tps from being jumpy?
Old May 29, 2009 | 10:39 AM
n8sz28's Avatar
Car: 85 camaro z28
Re: engine light on
also for the EST do you have to replace a piece in the distributor?
none of these codes should be from the transmission swap correct?
Old May 29, 2009 | 11:21 AM
BigBadLou's Avatar
Engine: TPI
Re: engine light on
If the TPS is "jumpy" and not smooth in operation, it would need to be replaced. Because if it sends incorrect readings to the ECM, that would cause trouble.
It's hard to tell whether the 42 code is for ESC or EST. I was under the impression that it's for ESC but I might be wrong. Let's wait for one of the mods to chime in, they should have a better idea.
No codes should be caused by a simple transmission swap. Unless you disturbed the harness when it was already barely making connection in some places. I'd check all the connectors and make sure that they are good and tight and that no wires are frayed.
Lou
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
