dry battery cell?
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
dry battery cell?
So for the last week every day it seemed that my car had less and less power to start it. I thought maybe something was slowly draining my battery but ive had it for three months and have not changed anything electrical wise in it. Today will washing the car I popped the battery covers off and the hole on the far left side(negative) was empty no water so I filled it then put the caps on and pulled the battery to check for cracks.
I found nothing wrong.
What could be causing this? I drive with no hood because mine was trashed.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: dry battery cell?
That's normal for a non sealed battery.
You're supposed to check the water levels periodically.
Be sure to use distilled water, too when filling.
Car: 96 Souped up Firebird, 89 KITT
i'd take it back under a warranty if you had one. you may be better off to get a sealed battery if you are driving 'nekkid' lol. suggestion: get one of the sears diehard platinum batteries.. awesome power and made differently than any of their other batteries.
3.8TransAM
Sep 27, 2015 08:37 PM
