somebody please help.
Old May 22, 2009 | 07:54 PM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
so, i just finished getting this thing all buttoned up, test drove the car a couple times, pulled it back in the driveway, and the ign switch binds up. so, i replace the ign switch, and now i have NO spark.
i've metered the power to the distro, and i've got the 12v needed. i've also replaced the coil with a new one, just to test it out. there is something inside the distro thats not working.
the thing is, is that is a brand new pro-comp billet distro with a 65k volt coil.
this is killing me. if there is anyone that knows a lot about an ign system, and is in the north texas area, i will make it worth your while to come help me with it. ie. gas money, food, beer, cash. whatever i have to do to get this thing driving right.
if you wanna help, PM me and ill give you my number and stuff.
thanks a lot
Old May 23, 2009 | 11:11 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: somebody please help.
MONEY......BEER....If I lived close by, I'de be your way. Sorry man. I live in sothern Cali. I hope you get your ride workin man. Have you tried a timing light? Call GM or some classic mechanic shop. They can probably help you. Run a diagnostic check using the little box under your steering column. You'll have to search the web on how to stich a paper clip in the slots and also to write down the blinking engine light codes. If there is a problem with a sensor, the ECM will probably tell you.
Old May 24, 2009 | 01:12 PM
thanks man. only problem is, is that my car isnt computer controlled anymore. the only thing its used for now is the lock up on the transmission. im goin straight old school now. haha
Old May 24, 2009 | 01:20 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Have you checked the voltage while turning the engine over ? If you don't have voltage you may want to check your igniton switch since your cylinder was hard to turn it may have moved .
Old May 25, 2009 | 12:42 PM
hey man. yeah. im getting 12v to the distro. well, 11.7....battery is kinda suffering since it hasnt been running.
Old May 25, 2009 | 01:22 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Your ignitin module may have gone out .
Old May 28, 2009 | 11:25 AM
it ended up being the mag pickup of all things. this thing is really startin to be a pain in my ***!!! lol
Old May 28, 2009 | 11:42 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Good to hear you got it that was my second thought of it being the pickup .
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
