Fuel pump or relay?
Old May 26, 2009 | 10:41 PM
backinblack05's Avatar
Fuel pump or relay?
I have a 1990 IROC-Z with the 350. I am having a hard starting problem on it. Sometimes I have to crank it alot of times before it will finally start. When I turn the key I can hear the pump kick on for the 2 seconds. When the car does start it will run for about 5-10 minutes and start running pretty rough and die sometimes. It has a adjustable fuel pressure regulator on it and the guage will show about 6 psi when the car is running. I am hoping that it is just a relay but I am thinking maybe not. Also I did put a new battery in it so that is not it. Anyone had the same experience or know what it may be? Thanks
Old May 26, 2009 | 10:53 PM
Re: Fuel pump or relay?
Could it also maybe be the fuel filter? Thanks
Old May 26, 2009 | 11:16 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
How much does the gauge show when you turn the key on and the fuel pump primes?
If only 6 psi, it's way too low for TPI. The injection system requires 38 psi at idle and 43 psi at WOT to run right.
Lou
Old May 26, 2009 | 11:27 PM
When I first prime it I think it gets up to around 10 -16. So what would that point at?
Old May 27, 2009 | 07:40 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Is the car carb TBI or TPI?
It is a 5.7 TPI
Old May 27, 2009 | 07:44 AM
Car: 1971 Camaro
Engine: 427
You may try and raise the pressure on the regulator, but as others said, that is way low for TPI.
Old May 27, 2009 | 08:42 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Way too low. If you can adjust it to 43 or so that's fine. Otherwise it's time to figure out why it's so low. Possibly time for a new pump.
Old May 27, 2009 | 09:44 AM
BigBadLou's Avatar
Engine: TPI
An easy check to eliminate the FPR or fuel pump:
- engine stopped, key off
- run the fuel pump continuously (you can use the standard paperclip trick)
- adjust the FPR to achieve 43 psi - if it works, test drive it
- if you cannot achieve 40+ psi, take vise grips and momentarily clamp the return fuel hose - if the pressure doesn't change (it should shoot up to 80 psi at least), the pump is bad
Hope this helps.
Lou
Old May 28, 2009 | 12:48 AM
I changed the fuel filter today. When i blew it, it came back out on my face so it was REALLY clogged. I drove it around for about 15 minutes and it seemed to run fine so I believe that fixed it.
Old May 28, 2009 | 08:49 AM
BigBadLou's Avatar
Engine: TPI
What's your pressure now?
Also, if the fuel pump ran for some extended periods of time with this clogged filter, make sure you test it long-term because it might now have some internal damage from the extra strain.
Lou
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
Kaweh
Aug 9, 2015 02:54 PM
