Relay Maybe??
Old May 31, 2009 | 11:49 PM
Jamie R's Avatar
Car: '88 GTA
Relay Maybe??
I just purchased a '88 GTA and have been taking out all the dang alarm system wiring someone put in the car at some time in its life. The alarm system no longer worked so I was trying to clean up some of the wiring in the car and that's the reason for the removal. Now my question is there is a metal relay? under the hood release handle inside the car with two wiring connectors plugged into it. The metal relay? with the 2 wiring connectors plugged into it, is this a factory piece for the gta's or something added? Any help would be greatly appreciated!!
Jamie R.
'88 GTA
Old Jun 8, 2009 | 11:02 PM
TiredRS's Avatar
Car: '91 Camaro RS
Re: Relay Maybe??
Is it behind the kick panel? There is a relay located behind the driver side kick panel and under the hood release handle. It is the starter enable relay for GM cars equipped with VATS (theft deterrent system). However, the relay should be plastic. Perhaps it is a relay for door lock actuators?
Old Jun 9, 2009 | 11:16 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Relay Maybe??
A picture and/or wire colors generally help with identifying electrical components.
Lou
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
