VATS problem
Old Jun 20, 2009 | 06:44 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
VATS problem
Yes, I did search. I was having problems with my car occasionally not starting, so I figured I would try the VATS resistor bypass. Unfortunately, whatever idiot had it before me had already done the resistor bypass, but in an extremely half-*** way, There were 2 4.7k ohm resistors spliced into the white wires coming off the connector for the VATS system (purple/white and black/white) So the resistance of my key measured about 1500 ohms. So I replaced the resistors (which were duct-taped in ) with a 1500 ohm resistor. Car wouldn't start.
So I wired back in 2 4.7k ohm resistors. Car won't start. Not getting any codes or anything, just a massive headache.
Someone please help me before I have an aneurysm. Are the two single white wires coming off the VATS connector supposed to connect to something? Or do they essentially make a loop from one terminal to the other? Because they weren't connected to anything before I started messing with it.
P.S. I hate when people do stupid things.
Old Jun 21, 2009 | 07:18 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Re: VATS problem
Nobody? The orange wrapped double-white wire has been clipped completely, I'm pretty lost on what to do now. It worked when the wire was clipped before, but wont now.
Old Jun 21, 2009 | 08:18 PM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
Re: VATS problem
try this thread: https://www.thirdgen.org/forums/elec...ese-wires.html
Old Jun 21, 2009 | 08:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: VATS problem
The two wires just connect to each other via a plug. I did the same thing years ago I actually cut the ends and just soldered a resistor in place on those white wires and then plugged it back in
are you sure you have the right resistance for you key?
(Set your meter to the 20k ohm setting)
VATS # (K)OHMS
1———— 0.402
2———— 0.523
3———— 0.681
4————-0.887
5————-1.130
6————-1.470
7————-1.870
8————-2.370
9————-3.010
10————3.740
11————4.750
12————6.040
13————7.500
14————9.530
15————11.801
few good pictures for ya
http://www.shbox.com/1/vats_bypass.jpg
https://www.thirdgen.org/tech/images...tanceTable.jpg
Once you disconnect the harness, put the key in the ignition and ohm check the wiring harness on the side with the two white wires.
If you get the value of the key then your problem with the VATS is somewhere else after the wiring harness.... The bypass won't work in this situation...
you could try one of these. No idea if they work., I always use a resistor.
http://cgi.ebay.com/ebaymotors/Vats-...171|240%3A1318
that should get ya started. hopfully you get it figured out.
Old Jun 21, 2009 | 11:17 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Re: VATS problem
I appreciate the help guys, I did find those threads when I searched, and had the right resistance from my key but when I used the right resistor combination, it didn't work.
Turns out the previous owner had soldered in a resistor waaaaay high up in the steering column.
That was a fun 6 expletive filled hours. Finally got it working now.
Old Jun 22, 2009 | 03:48 PM
Car: 1990 gta
Re: VATS problem
Well it's great that your problem is fixed but I am having a similar issue.
Checked the resistance with the key in the cylinder and I get the proper
value when I do.
So what do I need to look at next if the problem is after the harness.
I now have nothing going on when I turn the key. I have a bypass on order
and should be here soon.
I think I goofed somewhere along the line. What does the bypass module look
like and where EXACTLY is it located. I disabled something from the kick panel
area thinking it was a factory alarm system and chucked it. I hope that
wasn't the vats module.
Help!!
Old Jun 22, 2009 | 03:57 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Re: VATS problem
Kick panel as in...drivers side, left of the fuse panel? You may have chucked your starter relay...
No way you could've gotten rid of the VATS box, it's behind the passenger dash, from what I understand.
Old Jun 22, 2009 | 10:54 PM
Car: 1990 gta
Re: VATS problem
It's been chucked for a while (months) so I don't think it's the starter relay.
In fact I just ordered a theft deterrent relay from napa. Is this the same
as the starter relay?
Got a pic of the vats module?
I'm guessing the purple and white wires are going to it?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
