Rear Cargo light problem?
Old Jun 27, 2009 | 12:23 PM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Transmission: AUTOMATIC
Axle/Gears: POSI
The light in the center interior panel in the cargo area won't work and it doesn't have a switch to turn it on. I've changed the light bulb a couple of time but nothing seems to work. I've never seen it work before, has anyone had this problem and how did you fix it?
Old Jun 27, 2009 | 11:07 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Rear Cargo light problem?
Is the white wire plugged into a black with orange stripe wire? It provides the switched ground from the striker sensing switch of the pull-down unit to turn on and off the hatch light.
Lon
Old Jun 29, 2009 | 04:25 PM
TMMYJMMY's Avatar
Car: 1989 IROC
Engine: 5.7
Axle/Gears: POSI
well i check the wires and it is connected and and I checked and found that there was power on both ends of the bulb connects and i made sure the bulb was good. what now?
Old Jun 29, 2009 | 05:47 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm super sleepy and incoherent at the moment so I'm probably not thinking straight.
However, if the bulb contacts both show 12 volts, I'd say you have a short some place. One side should be 12 volts, the other side ground.
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
