high beam switch feeling different
Old Jun 29, 2009 | 07:02 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I noticed when I was driving home last night when I turned my brights on, the switch felt different. I had to pull it in hard before I heard the click to go from low beam to high beam. The brights and dims worked, but the lights went out briefly when I did it once or twice.. Anybody have any suggestions?
Old Jun 29, 2009 | 07:10 PM
Jr. Mechanic's Avatar
Car: 1983 Camaro Z28
Re: high beam switch feeling different
The dimmer switch located on top of the column is either going bad or is out of adjustment. Drop the column and it's easily accessible. A new switch is only about $15 bucks so it's worth replacing while you're in there.
Old Jun 29, 2009 | 07:34 PM
I'll drop the column and have a look. I haven't been using the darn thing though. Gotta figure out how to remove the column..
Old Jun 29, 2009 | 07:36 PM
Remove the trim piece directly below the column. There are two nuts (can't remember the size, wanna say 5/8) holding the column in place. Remove them and it will droop down enough for you to access the dimmer switch.
Old Jun 29, 2009 | 08:54 PM
Thanks Jr. I will tend to it in short order. I freaked when my headlights went out briefly. I wouldn't have made it home. I switched it on and off about 10 times and it cut out only twice.
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
