overhead console help
Old Jul 1, 2009 | 11:54 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
ok i just finished installing an over head console in my 86 iroc with t-tops which did NOT originally have the console.... main light orks fine, but the map light wont turn on... the switch is really tempermental.... it sticks and if you move it a bit the map light will come on.... is there ANY way of fixing the switch or am i screwed and have to buy another console???
Old Jul 2, 2009 | 07:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: overhead console help
Originally Posted by coryprine
the map light wont turn on... the switch is really tempermental.... it sticks and if you move it a bit the map light will come on.... is there ANY way of fixing the switch...
PMed. Try contact cleaner. I use a brand from CarQuest, but any should work--a quick dry type would probably be best.
JamesC
Old Jul 2, 2009 | 11:21 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
ok thanks james ill give it a try
Old Oct 8, 2009 | 01:36 AM
C.W's Avatar
C.W
Does yours have the trip meter and time?
If so do you have it wired and working?
Old Oct 8, 2009 | 06:56 AM
JamesC's Avatar
Those parts are mechanical.
JamesC
Old Mar 14, 2026 | 01:03 PM
G70's Avatar
G70
Car: 87 IROC 350, 88 restro mod, 68 conv
Reviving an old thread. I have a sticking switch as well. Any other suggestions people have to fix a sticking overhead console push button switch?
Old Mar 18, 2026 | 08:58 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Is the button centered around the hole? Sometimes it grinds against the housing (hole) and sticks. The switch has some "adjustment", but you may have to dismount the console and adjust the switch from behind.
Lbibb
May 5, 2016 12:00 AM
ndndndnd
Sep 28, 2015 08:00 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jetmeck
Sep 4, 2015 12:29 AM
