Digital dash Odometer HELP PLEASE
Old Jul 11, 2009 | 09:07 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
87 TRANS AM WITH DIGITAL DASH, CAN'T GET ODOMETER OR GAS GAUGE TO WORK. WITH GAS GAUGE IM THINKING SENDING UNIT CAUSE ITS AT 1/4 TANK ALL THE TIME AND ODOMETER NUMBERS I HAVE NO IDEA. ANY HELP TO GET THE NUMBERS TO APPEAR WOULD BE GREAT. EVERYTHING ELSE SEEMS TO WORK BUT THESE 2.
THANKS FOR THE HELP
Old Jul 11, 2009 | 10:21 PM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
Re: Digital dash Odometer HELP PLEASE
If a digital display is not lighting up and others are, then you need a new instrument cluster*.
If it is lighting up, but giving the wrong information, then I would check the wire providing the information to that gauge using a multimeter and a factory service manual set (which would give troubleshooting instructions). There could be a problem with the wiring, a connector, or the sensor.
*If you know how to work on electronic circuit boards, sometimes instrument clusters might have a loose solder connection or broken trace. Might take a peek and do a few checks with a multimeter.
Old Jul 12, 2009 | 07:14 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I have a spair cluster that i put in.same 2 gauges not workin
Old Jul 12, 2009 | 09:32 AM
Billy_Bob's Avatar
Engine: 5.7l
Transmission: 4L70
Well then you would need a factory wiring diagram which would be a part of a factory service manual set.
Then look at the diagram and see how these work. Where they get their power from.
Then test with a multimeter.
Also don't assume it is not a problem with the instrument cluster (because of the swap having the same problem). I've seen some products that have a part which tends to fail and all or most older parts have the same problem.
But you don't know for sure until you can look at a wiring diagram and see how everything works.
Old Jul 12, 2009 | 01:07 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
thanks i will look into it..thanks for the help
Old Jul 13, 2009 | 12:23 AM
ClassicCamaro's Avatar
Car: 1991 Chevy Camaro Rs
Engine: 5.0 L TBI currently building a 350
Transmission: its a drag automatic shif kit in it
Axle/Gears: stock i think
yeah what year is your car... i have two cluster for camaro
Old Jul 13, 2009 | 05:35 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
87 trans am
Old Jul 13, 2009 | 05:44 PM
i dont think my cluster would work since i know trans am and camaro are different kind of cluster.... srry.
Old Jul 14, 2009 | 08:01 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Thats what i was thinking.I was wondering why you said that.=) but thanks
Old Jul 16, 2009 | 09:50 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
im wondering if you have gotten this problem resolved because i am having the same problem with my odometer, i also have a 87 trans am. the odometer just keeps flashing 9999999
Old Sep 17, 2021 | 02:01 PM
jlweaver's Avatar
Car: 1989 Pontiac Trans Am GTA
Hi. I am wondering if anyone found a fix for this issue. My odometer also flashes 999,999 and will not give any other details.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
