Rear hatch pops while driving.
Old Jul 29, 2009 | 05:49 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
I recently rebuilt my hatch pull down on my 1989 IROC with parts from TDS, everything seem to work great, except it pops while driving on some of the rougher roads in the area. The switch is working properly and won't release the hatch when the car is in gear. Is there an adjustment I need to make ? Any help would be appreciated. Thank's
Old Jul 29, 2009 | 01:37 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
HATCHED AN IDEA
You need to find out if it’s being electrically released VIA a short, or if it’s being mechanically released.
You can find out a with a telltale fusible link across the release solenoid.
OR
It might be a mechanical problem.
Make sure the mechanism from the key tumbler thru the cam lever that releases the latch is OK and that the springs are still as strong as they should be.
When replacing parts it’s possible to over-bend springs, thus weakening them.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Jul 29, 2009 | 01:44 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: HATCHED AN IDEA
Mine pops about once a month with no electronics lol...doesn't bother me too much. Just that *click...WOOOOSHHHHHH* noise you here and are like wtf?
Old Jul 29, 2009 | 02:03 PM
NINÅ's Avatar
Transmission: 765R4
HATCHED AN IDEA 2
I have purposely opened the hatch while driving.
I can close it while driving also.
I merely have to go 60 or better and the air will close it.
I need to have one of the windows open a bit for that trick to work.
Happy Racing!
Old Jul 29, 2009 | 04:10 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Re: HATCHED AN IDEA 2
It is being released electronically ,then is raises as it should then the hyd. supports lift it the rest of the way.
Old Aug 24, 2010 | 08:32 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Update: The hatch still pops up every day I drive the car. At first I thought it was an electrical issue so I completely removed the solenoid to eliminate that issue and it still pops. When it's closed I can pull up on the deck lid and it feels solid and tight. Any suggestions would be appreciated.
Old Aug 24, 2010 | 09:13 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Rear hatch pops while driving.
Sounds as if the mechanical latch isn't catching properly. You stated that it would not "pop" while in gear but that it will "pop" while driving. It seems like the saftey feature is working, but it's not staying latched as it should ..... Once un-latched the pull down motor's "trigger" will sense that and go Up/Down as it's expected to do.
The only thing that will open the hatch on a working set-up is the release soleniod, or the key tumbler / cable. They have nothing to do with the Up/Down motion of the pull down unit. Stick your key in the hatch lock and see if it "springs back" after you turn it ! Like NINA said,..... be sure to check the Key Tumbler / Cam and that the cable from the key tumbler to the latch is OK and not binding up !
Old Jun 11, 2013 | 07:55 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
H, I am exeriencing he same thing. he hatch-pull down part work pefectly. When driving I hear the pop from the remote release solenoid and the hatch is open. I removed the control wire from the solenoid and it still happns. The key does not spring back when turned but moves freely.
What is the fusble link across he solenod? If I think it is the key elease cable how do I lubricate it or do have to get a new solenoid / release mechanism?
I aklready checked every wire for breaks and wear and tightened down evey ground nut.
When the car is off the hatch is tightly secure. Wth the control wire removed, the interior switch no longer works (as is expected) but even when connected it only worked with the parking brake on. Without power to the solenoid how can I still hear it activate?
Old Jul 1, 2013 | 05:51 PM
NINÅ's Avatar
Transmission: 765R4
The Odds Are ……..
That can be the problem.
Replace the spring to see if the problem goes away.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
Randomtask2
Aug 13, 2015 01:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
