Oil pressure gauge
Old Aug 4, 2009 | 03:19 AM
bearcats20's Avatar
Car: 1991 camaro Z28
Engine: 5.7 350 TPI with a performance chip
Oil pressure gauge
My oil pressure gauge likes to do its own thing it will work sometime and others it will do what it wants to, won't read, bounce around etc etc.could any one help? Oh its a 1991 z28 if that matter's about anything
Old Aug 4, 2009 | 03:35 AM
Shadow Z's Avatar
Car: Lots of 'em
Re: Oil pressure gauge
I know absolutely nothing about how the gauges even work, but it'd be a good idea to check the obvious first. Maybe check behind the gauges, see if any cables or wires are lose.
Old Aug 4, 2009 | 09:28 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Check the wires going to the Oil Pressure Sending Unit - it should be located just above your oil filter - there are 3 wires, two are larger, they run the fuel pump - the smaller one operates the guage.
Old Aug 4, 2009 | 05:44 PM
bearcats20's Avatar
alright thanks for the help
Old Aug 4, 2009 | 11:08 PM
shouldahadav8's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 350 4bbl
Transmission: Stock Auto
Axle/Gears: Stock
hey i was having the same problem - except i drive a 4bbl trans am
i had a friend install a new sending unit (so i dunno where it is) and it seemed to be working fine and it just crapped out on me one day.
it rests at the bottom, but when i turn the car on it flips all the way to the other side at full pressure and stays there
and ideas?
any and all help would be appreciated!
Old Aug 4, 2009 | 11:28 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
If it pops out for some reason it will do it. I know that if a wire melts and grounds out it'll do that. hope that's a start. I'm not sure about the lg4 being the same, but I think it connects to a fitting up top in the back of the motor.
Old Aug 5, 2009 | 07:32 AM
Engine: 350 4bbl
Axle/Gears: Stock
does anyone know where the sending unit is?
that was i can find it and run through all the wires
thanks!
Old Aug 5, 2009 | 10:32 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
thanks!
For your car I believe that its behind the intake manifold. Look to the right of your distributor, it should be a cylindrical metal thing, with a wire on the end of it.
Old Aug 7, 2009 | 08:22 AM
phanowel's Avatar
Would the SES light come on if the sending unit were faulty? That is, the computer would sense it and throw the light. If no light, then perhaps the gauge itself isn't plugged in correctly or is the culprit.
Old Aug 7, 2009 | 09:27 AM
PRMRD88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 89 Vette TPI 350
Axle/Gears: 3:73
I had to replace my sending unit last year. I hope you got small hands.
Old Aug 7, 2009 | 07:37 PM
Car: 1992 RS
Engine: Carbed 350
I don't think a bad sending unit will trigger an SES light - I've never seen mine go on because of a bad OPSU.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
