turn signal flasher question
Old Aug 14, 2009 | 05:40 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i'm trying to find my turn signal flasher.
i dont know the difference between my hazard and turn signal flasher
i only found one.
it has 2 connectors on it the plastic tab/s is red.
it is a round metal flasher.
it is on a U or C clip and attacthed by a pinching tab inside and above the ALDL connector.
is that the turn signal or hazard flasher? If not my turn signal than where else could it be?
also if i replace this flasher for one that can support leds will it messs up or support my rear taillight turn bulbs?
i'm only trying to replace my two front turn signals for LED since i just put blackouts on my 1986 trans am.
Old Aug 15, 2009 | 10:12 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: turn signal flasher question
Yup, you found it. That's exactly what that is.
The hazard flasher is in the "convenience center" which is a bigger plastic housing with relays and flashers plugged into it, it resides to the right of the steering column, under the dash.
Hope this helps.
Lou
Old Aug 15, 2009 | 11:12 AM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thank you
what is the convience center anyway? just so i know if i need to know later
Old Apr 12, 2016 | 05:37 PM
tecboy's Avatar
Engine: 350 - 305 801 Heads
Axle/Gears: Stock
convenience center not so convenient lol 1984 z28. Notice just above it is the flasher
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
