turn signal problem
Old Aug 20, 2009 | 12:01 AM
polaris91's Avatar
Car: 88 camaro z28
turn signal problem
hi guys i just recently purchased my first car an 88 camaro z28 and im having a problem with the blinkers whenever i try to turn them on (left or right) it actualy turns on the hazards instead of the blinkers anybody know what my problem could be? thanks alot
Old Aug 20, 2009 | 09:20 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: turn signal problem
If your harness is all original and hasn't been hacked, I would first suspect the multifunction switch in the steering column.
Lou
Old Aug 20, 2009 | 10:36 AM
1Aauto's Avatar
Former Sponsor
Welcome to TGO.It sounds like it could be the turn signal switch in the column acting up. If you find out that it is we have them instock. Here's a link to them on our site.
Camaro Turn Signal Switch
Old Aug 21, 2009 | 01:58 PM
polaris91's Avatar
Car: 88 camaro z28
i think i figured it out im not sure if this is how its supposed to work or not? when the hazards button is pushed in they dont come on unless i hit the turnsignal is that how theyre supposed to work? because i pulled the hasards switch out (i belive it may have been vise versa) and then the blinkers worked as they should
thanks
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
