reverse lights on t5 swap
Old Aug 24, 2009 | 08:38 AM
mjustice's Avatar
I put a t5 with a cable driven speedo in place of t5 with an electronic speedo. Bought a converter for the speedo, works fine. When I shift into reverse, the reverse lights do not come on. Is there some type of electrical connection somewhere on the tranny? If so, is there any way to wire it to the existing electrical harness or will I have to make a completely separate circuit? I swapped the tranny 3 years ago, didn't notice the reverse lights for some time, didn't care till now.
Old Aug 24, 2009 | 11:09 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: reverse lights on t5 swap
Yes, there's a two-prong plug on the driver side of the transmission. You should have an unused two-prong connector hanging by the transmission. The wire colors would be blue and green.
Hope this helps.
Lou
Old Aug 25, 2009 | 01:45 PM
mjustice's Avatar
The plug is connected to the switch as it should be and the bulbs are good. Is there anything else that I should check before replacing the swithch?
Old Aug 25, 2009 | 02:19 PM
BigBadLou's Avatar
Engine: TPI
YES, the source of the problem!!
Before you throw any parts/money at a problem (common mistake made daily by many), find out first what you need to replace.
The B/U circuit is one of the simplest. Diagram here: http://www.austinthirdgen.org/mkport...kup_lights.jpg
If your turn signals work, that means the fuse is good (it is shared with the B/U circuit).
So at this point, you have only two possible points of failure:
- switch
- wiring
Unplug the switch connector. Put a testlight in the blue wire and turn the ignition on.
Does the test light light up?
No -> diagnosis: wiring problem between fuseblock and switch.
Yes -> continue below.
Insert a paperclip in the connector and turn the ignition on.
Do the reverse lights light up?
Yes -> diagnosis: bad switch.
No -> wiring problem between the switch and lightbulbs (possibly bad sockets).
Hope this helps.
Lou
Old Aug 25, 2009 | 02:52 PM
mjustice's Avatar
It's the dadgum switch!!! Thanks.
Old Jan 26, 2015 | 07:38 PM
chevy2424's Avatar
What speedo adapter did you use i have one but its not working also how did you wire it i used my wiring from my old vss from my auto
Old Jan 26, 2015 | 09:19 PM
mjustice's Avatar
I used a 2000 pulse adapter. Bought the cheapest one I could find on ebay - don't remember what brand. Wiring to the old VSS is correct.
First, check and see if you need a 4000 or a 2000 pulse for your ECM. If you have the correct one, see if your ECM is reading speed and your speedometer is not displaying it. If you have the correct one and your ECM is not reading speed, you may have a defective sensor. Also, make sure the square hole the adapter fits in rotates when the wheels are rotated (in gear of course). The site below will tell you which pulse adapter you need.
http://www.jagsthatrun.com/Pages/Spe...eedometer.html
Best of luck!
Old Jan 26, 2015 | 10:01 PM
chevy2424's Avatar
Best of luck!
Mine is carbed when i researched they said 2 pulse so thats what i got and alright i'll give what you mentioned a try thanks
Old Jan 26, 2015 | 10:04 PM
chevy2424's Avatar
Also how can you tell if its rotating when the wheels are spinning thanks again
GTAman
Jul 3, 2024 07:29 PM
Fronzizzle
Feb 9, 2017 09:31 AM
skeltor
Feb 2, 2016 10:37 AM
Luigytico09
Oct 1, 2015 08:46 AM
gta892000
Sep 16, 2015 12:37 AM
