Bad ground, but where?
Old Sep 20, 2009 | 07:32 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I noticed my turn signals seemed to blink a little faster than normal, but didn't worry much about it. But I drove my car the other night (unusual) and when I pulled the headlights on, the turn indicators lit up some along with the bright light indicator. Am I looking for a under dash ground problem or one near the actual lamps?
Old Sep 20, 2009 | 07:50 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Bad ground, but where?
i think they ground near the headlight on the rad support not postive though and the back s ground inside where you unscrew the light assemblies
Old Sep 20, 2009 | 08:18 AM
acole88's Avatar
check your parking lamp bulbs...
Old Sep 24, 2012 | 06:23 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Ok, so I still have this going on intermittently and I tried fixing it today. After I finally found G200 on the "convenience center", I loosened and retightened it. That didn't seem to to fix it. I also loosened and retightened the headlight grounds. No help.
I can bang my hand on the bottom of the dash with the knee bolster removed and cause it work properly. It's obviously a ground, but not the G200 instrument panel ground itself. It's like the bracket and dash metal isn't grounded good.
Old Sep 25, 2012 | 02:15 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
After tinkering yesterday and burying my head in the factory manual, I believe it's going to be in the C2 connector to the instrument panel. Pin 14 is the ground that should be used by the bright light indicator and the turn signal indicators when they are being powered by the flasher. I believe this connection, factory splice 205 or something in the instrument panel circuit board itself (such as a crack) is causing this ground to become intermittent or to have small amount of resistance.
If that ground path is severed or has high resistance, electricity will find its way to ground thru the front turn signal indicator bulbs and then thru the actual front turn signal bulbs themselves since they are very low resistance when not lighted.
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
TheTraut88
Sep 11, 2015 05:16 AM
Gunsbee
Sep 7, 2015 07:10 PM
Amillionoh7
Sep 5, 2015 11:44 PM
