power lock problem
Old Oct 11, 2009 | 06:56 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
power lock problem
Going to be doing alarm with keyless entry pretty soon so i guess i will finally fix this. The door locks will work but u have to press the button about 5 times before the locks will be completely locked or unlocked. Both sides are about the same. Is this a wiring issue with not enough power going to them? do i need new lock actuators? or do i just need to grease all the moving parts in my door?
Old Oct 11, 2009 | 07:02 PM
mikeyg785's Avatar
Car: 1986 camaro iroc z28
Engine: 305 tpi
Axle/Gears: stock 2.23
Re: power lock problem
i dont know how much this helps becuase i have done anything to my car but...i have the same problem, and when i brought my car to the shop they said it needed new actuators. i havent replaced them yet so i dont know if thats the problem. anyway hope that helps and im interested to hear your results.
Old Oct 11, 2009 | 07:03 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Try cleaning the grime build up on the slides. Common problem...Try the cleaning before going off the deep end.
Old Oct 11, 2009 | 07:29 PM
mikeyg785's Avatar
Engine: 305 tpi
good to know. u know mechanics, just probably trying to get money
Old Oct 11, 2009 | 07:34 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
will clean that tomorrow and see how it does, maybe i should have done that today when i had the panels off painting them lol
Old Oct 12, 2009 | 03:02 PM
87SnowFlake's Avatar
Car: 87 IROC-Z
Engine: jasper 350
Transmission: 700R-4
Axle/Gears: 2.73 posi
my power locks didn't lock on their own power at all. I took my door panels off and soaked them with PB blaster (you can use any solution that breaks down rust) and they work like a charm.
Old Oct 12, 2009 | 03:42 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Usually just need lubed up, pretty common thing among third gens I have came across.
Old Oct 12, 2009 | 04:22 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Ok i have this problem also. And i have a full can of PB blaster in the cabinet(actually two lol)
What exactly did you spray all to get it to work. My drivers one works great but my passenger one only goes half way. I have a remote 2 way alarm and i want to get this fixed soon so when i pull on the passenger door handle the door comes open and i forget my alarm is on and look like im stealing my own car.
...Did this at the movies trying to be nice and let the girl i was with in the car. Set off the alarm and ouuu look there is the cop conviently right THERE!...i had to prove it was my car and all that crap. PITA for no good reason. The fact that i forgot i had the alarm on was stupid in the first place but i was more focused on other things at the time lol
Old Oct 12, 2009 | 05:25 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
LOL I can just imagine that must have been funny... Anyways about a year ago i rebuilt my doors completely only to screw up the door locks even more... I replaced the door lock actuators and now it just doesn't even work at all or very little... No matter how many times i press it, it won't work... I sprayed lithium grease in there and it doesn't work anymore... Was that the wrong thing to spray or should i have just sprayed WD-40 or something?
Thanks,
-Marc
Old Oct 17, 2009 | 07:26 PM
I use graphite lube. Clean the inside of the latch with brake/carb cleaner to get the gunk and crap out then liberaly spray the graphite lube in as I lock and unlock the door.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Bert87
Aug 23, 2015 03:50 PM
