No start issue...have wiring questions
Old Oct 18, 2009 | 04:40 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Alright, I have posted another thread on this problem, but I have since discovered some more info. about the wiring and have narrowed down my search for my current no start issue.
Basically, I have an '88 Trans-Am with the 305 TPI, auto. trans. I have no power being sent to the starter solenoid when I turn the key...basically, I get nothing when I turn the key. The battery is good, it doe not have the VATS, and the rest of the harness has been put back together as far as I can tell since I pulled the dash out for firewall repairs. I took power from the battery and directly touched it to the back side of the larger 10 gauge purple wire on the fuse panel labeled "crank" and the car cranked over and started. So it is somewhere in the starting circuit between there I guess. There is a smaller like 16 gauge wire that is purple with a white stripe going to the other side of the "crank" fuse that I imagine supplies the power to the larger wire when engaged/activated from wherever it is activated from between the key and that fuse. That is where my issue lies and where I need a troubleshooting diagram or wiring diagram of some detail to help me diagnose this. In short, where does the power come from between the key to the fuse panel which then supplies to the starter itself? That is where I am at on this now.
Old Oct 18, 2009 | 08:07 PM
Car: '87 Trans-Am
Re: No start issue...have wiring questions
All I really need is a decent wiring diagram or troubleshooting tree so I can figure it out myself...
Old Oct 18, 2009 | 09:04 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I think that the smaller purple/white wire is for the cold start injector.
I'd check all your fuseable links and any In-Line fuses to be sure there is no problem there. Sorry - I don't have a 88 diagram for Ya' !
Old Oct 19, 2009 | 02:01 PM
Car: '87 Trans-Am
Alright, finally figured it out. I knew it was a plug somewhere not plugged in...my dumb *** missed the plug to the neutral safety switch. I had a feeling it was a problem somewhere in that safety switch circuit...that's what it was.
Old Oct 19, 2009 | 03:36 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Quick question for u? How did u rule out that the ignition switch was not out?
Old Oct 19, 2009 | 07:07 PM
Car: '87 Trans-Am
I tested the wires coming from it in the on position and while in the crank position and had signal when cranking off the ignition switch...so I knew it had to be down line somewhere.
Old Oct 20, 2009 | 08:34 PM
Engine: 350 tpi
And which wire was that sorry its cause ive had this problem for awhile
Old Oct 23, 2009 | 11:55 PM
91aress's Avatar
I too have this same problem on my 91rs auto 305. have not been able to start it for the last month, every 100 tries itll turn over, start, and die right away. Any ideas? was it the nuetral safety that went out then or bad wiring? THanks
Old Oct 24, 2009 | 11:07 AM
Car: '87 Trans-Am
Hey, sorry, no longer subscribed to this thread. The wire I tested at the column was the yellow wire out...meets down the column into one of the 3 big harnesses down there...you'll see them when you pull off the plastic trim piece. You should have power to one of the larger gauge wires all the time...I think it's red on mine, and the yellow one will light up/show voltage when you turn the key. I have a trans-am, so I have wiring for both manual and auto. trans cars. So I had a wire for the clutch switch near the fuse box as well as the harness for the neutral safety switch at the gear selector. It turned out I just somehow missed the plug for the neutral safety switch...plugged it in, fired right up.
If you are getting the car to crank over, it is not likely one of these wiring issues. If the neutral safety switch/wiring or ignition switch are the issue, the car wouldn't crank over normally at all. Unless it is loose or has a bad connection of some kind in the ignition cylinder and wiggle causes it it to shut off because it thinks you turned the key off or something, I would think the issue is elsewhere if the car cranks over but doesn't start.
Old Oct 24, 2009 | 12:56 PM
Engine: 350 tpi
well on mine it just wont turn over at all...so i apply voltage to the yellow thick wire coming down from the ignition ur saying and see if it will crank over?
Old Oct 24, 2009 | 01:17 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Yea. Sounds like that what he is saying. Sounds like ignition switch and neutral switch is always the colprit if you haven't touched the wires and it just suddenly done this by not starting. My ignition switch actually fried after so many times to get it start it would start then days it wouldn't. Then SMOKE one day it started. Thats how i knew my ignition switch was bad.
Old Oct 25, 2009 | 07:01 AM
Car: '87 Trans-Am
NO...the yellow wire is where I am checking for voltage. I don't know what will happen if you apply voltage to it...probably nothing. Yellow is where I have the test light or multimeter on to see what voltage and when. There is a purple wire about the same gauge that runs right nest to the yellow wire on the clutch safety switch and the neutral safety switch by the gear selector. It also runs up into my fuse panel box under the dash behind the fuse labeled "crank". It's the only solid 10 gauge purple wire in my fuse panel. Put power to it and it will probably crank. If it doesn't...you have a similar issue...probably neutral safety switch or starter.
Old Oct 25, 2009 | 10:10 PM
91aress's Avatar
I still am having same issue and been following the tread as you guys post trying to figure this all out. (91 305 rs auto) My yellow wire is getting voltage, maybe not enough?? whats it supposed to read? How would i apply voltage to the purple wire? I dont think its the nuetral safety cus when the wires were all grabbed and wiggled while trying to turn over, got like half a crank. So stumped from here.
I was throwing a code before this all happened but now that the compter was unplugged and plugged back in its not registering, is that normal? Thanks for the help!
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
