what size wire for alternator to cutoff switch and batter in trunk
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
I relocated my battery to the trunk a couple months ago and i am yet still to properly wire my alternator. The way i have it setup now if i were to cutoff my switch my car would still run off the alternator which is not what i want, its not safe either. I need to run my big power wire from my alternator to the battery side of the switch my question is
what size wire should i run and where to get it?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: what size wire for alternator to cutoff switch and batter in trunk
depends on the alternator rating and the electrical load
-if it's a stock alternator and close to stock electrical load
6 or 4 GA should do it,i'd lean towards the 4 GA if you
pull more than 70a often.Be sure to put a fuse of about
200a on the alt end.
my local farm/ranch store has wire suitable,other stores
to check include welding shops,RV shops,car stereo,4x4,
industrial electric shops etc.
i only have the basics like power windows power door locks, soon to be installed msd 6al-2 programmable box, electric fans, electric fuel pump, no subs or amps. do you think 6 gauge will do? i hate running thick wires under the carpet haha
Car: '82 z28
Engine: L83 5.7
6 ga should be good,sounds like you will be under 50a
most of the time
most of the time
Car: 1987 Trans Am
Engine: LQ9/L92
I would definitely have a fuse in-line when running wire that length. Cheap insurance when playing with lots of power
Also, there's more than enough room under the door sills for 4ga to be run. There are channels for the factory wiring under there that can be used just for a job like this. It never hurts to go too big.
Car: 1987 Trans Am
Engine: LQ9/L92
any time you have a power wire wire carrying a sizable amount of amperage, you should fuse it. It doesn't take much to cut the insulation and short out to the body, especially when around moving parts and going through body panels (remember to always use grommits!). Its much cheaper to replace a fuse than a car. As for the size of the fuse, never exceed the amperage rating for the length and gauge. Dug this chart up to demostrate the MAX ratings of wire by length.
Car: '82 z28
Engine: L83 5.7
100a fuse will be good for the alternator wire,200a
might be marginal for the starter wiring unless you are
using one of those japanese gear reduction starters
-just try it, if 200a blows,up it to a 300a
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
db057
Aug 11, 2015 10:11 PM
knight72
Aug 10, 2015 09:32 PM
