headlight motors being freakin stupid
Old Nov 3, 2009 | 06:57 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Ok, headlights were working fine last night on the formy, they were both going up and down freely. This morning however, I go to hit the lights, only the drivers one pops up and nothing from the other one. I have replaced both in the past so I know that when one goes bad, the **** on it spins like crazy, but this didn't happen here. No response from the passenger side motor, and the light on that side does come on, it's just shining downwards. Can someone tell me what the heck is wrong here?
Old Nov 3, 2009 | 07:29 AM
AmorgetRS's Avatar
Re: headlight motors being freakin stupid
What year is the car?
Old Nov 3, 2009 | 08:14 AM
all4u's Avatar
Car: Firechicken
89 formy 350 tpi.
Old Nov 3, 2009 | 11:13 AM
AmorgetRS's Avatar
Have you tested to see if it is getting any power? Just unplug the headlight motor and put a volt meter on the car side of the plug. Have someone flip on the headlights and see if you have any power going to the headlight. If not, it may be that the headlight module died.
Old Nov 3, 2009 | 11:29 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
With the headlights switched on, try tapping on the headlight module and see if it goes up. I had a similar problem, and it wound up just being dirty relay contacts inside the module. I took it apart and cleaned the contacts, and it's been working fine since. The module is on the drivers side of the firewall, near the relays, it looks like this:
Old Nov 3, 2009 | 07:07 PM
all4u's Avatar
Car: Firechicken
Thanks for the replies. I will try out the suggestions tomorrow. I just got home from work (took the fiero to work) and it is dark outside. I will give an update in the morning. That would be weird if it was the module because one headlight works and the other doesn't. The driver's one flips up ok. I don't get it. I'll see what happens tomorrow.
Old Nov 3, 2009 | 09:24 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
how did you take it apart and does this make your lights pop up when you turn the daytime lights on too
Old Nov 4, 2009 | 04:32 AM
all4u's Avatar
Car: Firechicken
the headlights don't pop up with the parking lights on. I'll see about testing for power when the sun comes up.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
Cleotiz
Jan 6, 2018 08:56 PM
LittleFranks
Sep 17, 2015 12:22 PM
