Dash Lights
Old Nov 9, 2009 | 05:27 PM
schroff's Avatar
Car: 1990 firebird
Engine: V6
Axle/Gears: rear axel has some 9 bolt pattern
Dash Lights
So i just got my first Firebird its a 1990 and my dashlights are not coming on i have an INFL. REST light that comes on which has something to do with airbags so since that light comes on i dont believe it is electrcal if anyone can help please do also i have checked the fuses and one more thing my speedometer works once in a while but sometimes it just gets the wiggles and other times it just doesnt work
Old Nov 11, 2009 | 10:50 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Re: Dash Lights
You will always have the INFL REST light on if you no longer have the airbag (hence it lighting up indicating there is a problem with the Inflatable Restraint system). Best thing to do is just remove the light bulb from the instrument cluster assembly.
As for the speedometer phasing in and out, check the connection of the speedometer sensor that attaches to the rear tailhousing of the transmission (will be a purple and yellow two-wire connector). Make sure it is seated well. The Electronic Speedometer Sensors were used on Firebirds from 1986-up. Camaros got them around '90 I think.
Old Nov 16, 2009 | 11:23 PM
Osbert's Avatar
Re: Dash Lights
Dashboard BRAKE light is on when your emergency brake is off, it usually means you need to add brake fluid. Check the level and add some fluid as needed. If the light still doesn't go away, you should probably take your car in to have the brake system properly diagnosed.
Old Nov 17, 2009 | 09:34 AM
thirdgen88's Avatar
Car: 1995 Corvette
Re: Dash Lights
This is correct, although he just has the Inflatable Restraint light on, the brake light is off and functioning correctly.
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
