Headlamp Door Won't Raise
Old Nov 18, 2009 | 08:51 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
If I knoack on the door. it sometimes opens. Or I have to pop the hood, then flick the adjuster **** and the door magically raises. Sometimes it actually works properly on its own
Do I need a rebuild kit? I've tried to adjust it, but nothing changes.
Old Nov 18, 2009 | 09:11 PM
Stephen's Avatar
Car: 87 GTA
Re: Headlamp Door Won't Raise
Headlight Control Module on the fireawall. When they work off & on, there is a short in it somewhere. Open it up & see if you can find a cracked solder connection, causing it to work off & on.
You could just buy another one, but try fixing yours first.
Old Nov 18, 2009 | 11:22 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Well if your knocking on the headlight lid and the pop-up motor to get it to raise up, and you are NOT tapping on the headlight Control Module on the fireawall to make it lift. Then it sounds like the me that you might need a rebuild kit!!!
Q. When your lights Do pop-up, do they bounce up and down a little bit when your driving? (if so, then I would have to say its time for a rebuild kit). Ebay has them for $3.00-$8.00 US.
Old Nov 18, 2009 | 11:49 PM
ericgzhc4t's Avatar
Car: 1986 Transam/1996 Trans AM
Engine: 5.7 LT1 .030 over
Transmission: Borg-Warner T-56 6 speed
You should really check out this web site, it finally solved my problem,
Thanks,
Eric.....http://www.manxyanks.com/82-86%20Fir...ot%20guide.pdf
Old Nov 19, 2009 | 04:58 PM
Car: 1986 Trans Am
Engine: 5.0
No, they stay steady. It just need a slight push on the ****. That **** keeps trying to take off my finger if I'm not careful It always works when I give it a slight turn.
Old Nov 20, 2009 | 02:52 PM
Car: 87 T-Top GTA
LOL, yeah watch out for that.
Q. Do you need to push on both *****, or is it just the one side that keeps on sticking??? I'm starting to wonder if your problem is the motor itself...If so I don't think there's a rebuild kit for that!!! And if there was a kit, I don't know how to fix a electric motor! I NEVER did one before.
Old Nov 20, 2009 | 03:04 PM
Stephen's Avatar
Car: 87 GTA
When my driver's side headlight was doing that, it was just a loose nut on one end of the lifting arm link. Tightened it up & all has been good ever since.
Old Nov 20, 2009 | 03:18 PM
Car: 87 T-Top GTA
Yeah, I read that post of yours on another thread somewhere. Lucky you!!!LOL That was a Cheap and Easy fix. But I think by the sounds of it that his "arm" isn't loose. I'm still leaning towards the motor.
Old Nov 20, 2009 | 08:05 PM
Car: 1986 Trans Am
Engine: 5.0
I only have to rotate the LH **** a little bit, then wooosh it opens right up
Old Nov 20, 2009 | 08:37 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Thanks,
im gona have to look at that one of these days, mine wont go up, they will go down on their own, but I have to manually open them
thank god Im still restoring it and i dont have to do that every night.
Old Nov 20, 2009 | 10:46 PM
Car: 87 T-Top GTA
What do you mean by manually?...Do you turn the motor **** by hand?
Old Nov 21, 2009 | 10:09 AM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
yeah. Like to get my headlamps up I have to turn the ****, but they go down on their own
Old Nov 22, 2009 | 09:08 PM
Car: 1986 Trans Am
Engine: 5.0
I took the cover off of the motor and cleaned it out with brake clean. Got a bunch of black dust and it all looked new and purdie
It works better, but the same basic problem is there. I used a jumper wire to a different ground, but it started blowing fuses
It still acts like it need a little extra ooomph. I'm not sure if the **** needs help turning or getting pushed down so it can turn. Weird problem, but I will eventually kick it's butt...even if I have to replace the motor
Old Nov 23, 2009 | 02:57 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
Ok i figured it out
problem #1 you dont need your headlights, you are a blind driver.
Old Nov 23, 2009 | 09:36 PM
Car: 87 T-Top GTA
Ok i figured it out
OMG, LOL, lame but funny!
Attached to the motor is what I like to call "the headlight Tranny" for lack of better words! I would guess that 80-90% of headlight pop-up problem are caued by the internal parts of this "Tranny", it acts like a tranmission for the motor, and inside are 3 small plastic rings that WILL wear out over time. That's why I've been asking you guys if your headlight bounces up and down a little. If it does bounce, 99% of the time it is that "Tranny". You can buy rebuild kits($3.00-$10.00 on Ebay). If it was me, I would open up the Tranny to take a look inside. If there are little bits of white plastic or white dust inside it.....Buy a kit! If not, rebuild motor or replace it!
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
