Key is sticking. Wanting to replace ignition cylinder
Old Nov 22, 2009 | 08:55 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
When trying to take the key out of the ignition it is sticking in lock and we have to push in button and giggle a certain way for it to release. Any ideas on how to fix this problem or do we have to replace the whole cylinder? If replacing the cylinder can i just find the vats code and install the proper resistor then put in any ignition cylinder. I just want the easiest and cheapest solution. Thanks
Old Nov 22, 2009 | 10:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Key is sticking. Wanting to replace ignition cylinder
Replacing the ignition cylunder doesn't change the vats any - just get a new key made from the new lock key dummy but with the old key's vats chip value.
You'll need a steering wheel puller to change the lock cylinder - a "free" rental at autozone or advance auto. Swapping out is pretty straightforward - just take it apart until you get there, swap, and put it all back together in reverse order. Took me about 2 hours my first time.
Old Nov 22, 2009 | 11:13 PM
Car: 91 RS T-top
So how much is a new cylinder. You think I just need a new key? It wont always unlock for the key to remove.
Old Nov 23, 2009 | 06:18 PM
Car: 1992 RS
Engine: Carbed 350
You could try a new key - but I'd get one cut from the original if available. Go to any ACE Hardware -they cut 'em for $20. If you don't have the original, but you get a key that works, then immediately go back and have another key made from THAT one, and keep the first one as an original - that way you will always have a good key to get copies made from.
This is the FIRST thing everyone should do when they get a car - make a master key and keep it a master (not to be used).
If you need a new lock cylinder, they are about $50 IIRC. Call Carquest or Napa if in your area - their parts are much better.
Old Nov 23, 2009 | 10:07 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
advence is actually starting to get the same parts as napa at the same prices. i just got a new ignition cylinder at advance for $18.99 chrome with 2 keys. i checked out the one napa had, same exact thing just more money. replaced ALL the locks on my car for less than $30, cheaper than napa, even with my buisness discount, and same parts
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
MY87LT
Aug 17, 2015 08:43 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
